Re: SCript won't stop
Posted: Sunday 04 February 2018 18:15
type the Domoticstestring.py file
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
Killing a process is not a very elegant way to stop a script. Why not create a temp file before you enter the while true loop and within the loop build in a check if this file stil exist. If not --> exit the loop and script.pascalbianca wrote: Friday 16 February 2018 17:29 Well thx for thinking but i don't want to run it once.
I want that the script runs when i push the button on and when i push the button off then the script stopts.
Running is no problem but stopping the script.
Change script that starts the python topascalbianca wrote: Saturday 17 February 2018 16:25 I'm sorry @waaren but i did read that link but still i don't know how to make it work in my code.
Can you help me please?
How do i make a temperyfile that contains my code?
#!/bin/sh
touch /tmp/AllowDomoticstestring
sudo PYTHONPATH=".:build/lib.linux-armv7l-2.7" python /home/pi/rpi_ws281x/python/examples/Domoticstestring.pyCode: Select all
# NeoPixel library strandtest example
# Author: Tony DiCola ([email protected])
# Direct port of the Arduino NeoPixel library strandtest example. Showcases
# various animations on a strip of NeoPixels.
import time
from neopixel import *
import argparse
import signal
import sys
import os.path
def signal_handler(signal, frame):
colorWipe(strip, Color(0,0,0))
sys.exit(0)
def opt_parse():
parser = argparse.ArgumentParser()
parser.add_argument('-c', action='store_true', help='clear the display on exit')
args = parser.parse_args()
if args.c:
signal.signal(signal.SIGINT, signal_handler)
# LED strip configuration:
LED_COUNT = 7 # Number of LED pixels.
LED_PIN = 13 # GPIO pin connected to the pixels (18 uses PWM!).
#LED_PIN = 10 # GPIO pin connected to the pixels (10 uses SPI /dev/spidev0.0).
LED_FREQ_HZ = 800000 # LED signal frequency in hertz (usually 800khz)
LED_DMA = 9 # DMA channel to use for generating signal (try 10)
LED_BRIGHTNESS = 20 # Set to 0 for darkest and 255 for brightest
LED_INVERT = False # True to invert the signal (when using NPN transistor level shift)
LED_CHANNEL = 1 # set to '1' for GPIOs 13, 19, 41, 45 or 53 <<<staat op gpio 13
LED_STRIP = ws.WS2811_STRIP_GRB # Strip type and colour ordering
# Define functions which animate LEDs in various ways.
def colorWipe(strip, color, wait_ms=50):
"""Wipe color across display a pixel at a time."""
for i in range(strip.numPixels()):
strip.setPixelColor(i, color)
strip.show()
time.sleep(wait_ms/1000.0)
def theaterChase(strip, color, wait_ms=50, iterations=10):
"""Movie theater light style chaser animation."""
for j in range(iterations):
for q in range(3):
for i in range(0, strip.numPixels(), 3):
strip.setPixelColor(i+q, color)
strip.show()
strip.setPixelColor(i+q, 0)
def wheel(pos):
"""Generate rainbow colors across 0-255 positions."""
if pos < 85:
return Color(pos * 3, 255 - pos * 3, 0)
elif pos < 170:
pos -= 85
return Color(255 - pos * 3, 0, pos * 3)
else:
pos -= 170
return Color(0, pos * 3, 255 - pos * 3)
def rainbow(strip, wait_ms=20, iterations=1):
"""Draw rainbow that fades across all pixels at once."""
for j in range(256*iterations):
strip.setPixelColor(i, wheel((i+j) & 255))
strip.show()
def rainbowCycle(strip, wait_ms=20, iterations=5):
"""Draw rainbow that uniformly distributes itself across all pixels."""
strip.setPixelColor(i, wheel((int(i * 256 / strip.numPixels()) + j) & 255))
strip.show()
def theaterChaseRainbow(strip, wait_ms=50):
"""Rainbow movie theater light style chaser animation."""
for j in range(256):
for q in range(3):
strip.setPixelColor(i+q, wheel((i+j) % 255))
strip.show()
# Main program logic follows:
if __name__ == '__main__':
# Process arguments
opt_parse()
# Create NeoPixel object with appropriate configuration.
strip = Adafruit_NeoPixel(LED_COUNT, LED_PIN, LED_FREQ_HZ, LED_DMA, LED_INVERT, LED_BRIGHTNESS, LED_CHANNEL, LED_STRIP)
# Intialize the library (must be called once before other functions).
strip.begin()
#print ('Press Ctrl-C to quit.')
while os.path.isfile("/tmp/AllowDomoticstestring"):
print ('Color wipe animations.')
colorWipe(strip, Color(255, 0, 0)) # Red wipe
colorWipe(strip, Color(0, 255, 0)) # Blue wipe
colorWipe(strip, Color(0, 0, 255)) # Green wipe
#print ('Theater chase animations.')
#theaterChase(strip, Color(127, 127, 127)) # White theater chase
#theaterChase(strip, Color(127, 0, 0)) # Red theater chase
#theaterChase(strip, Color( 0, 0, 127)) # Blue theater chase
print ('Rainbow animations.')
rainbow(strip)
#rainbowCycle(strip)
#theaterChaseRainbow(strip)
