SCript won't stop
emme
Domoticz version: latest
Re: SCript won't stop
Post by emme »
type the Domoticstestring.py file ;)
"We always done this way"
freijn
Domoticz version: Stable
Post by freijn »
dump/show the content of the py file to us please is that he asked for :-)
freijn
Post by freijn »
if you just want to run this once you remove the
while True:
shift all under it 1 tab to the left and you are done :
i.e.
# Create NeoPixel object with appropriate configuration.
strip = Adafruit_NeoPixel(LED_COUNT, LED_PIN, LED_FREQ_HZ, LED_DMA, LED_INVERT, LED_BRIGHTNESS, LED_CHANNEL, LED_STRIP)
# Intialize the library (must be called once before other functions).
strip.begin()
print ('Press Ctrl-C to quit.')
print ('Color wipe animations.')
colorWipe(strip, Color(255, 0, 0)) # Red wipe
colorWipe(strip, Color(0, 255, 0)) # Blue wipe
colorWipe(strip, Color(0, 0, 255)) # Green wipe
#print ('Theater chase animations.')
#theaterChase(strip, Color(127, 127, 127)) # White theater chase
#theaterChase(strip, Color(127, 0, 0)) # Red theater chase
#theaterChase(strip, Color( 0, 0, 127)) # Blue theater chase
print ('Rainbow animations.')
rainbow(strip)
#rainbowCycle(strip)
#theaterChaseRainbow(strip)
pascalbianca wrote: Friday 16 February 2018 17:29 Well thx for thinking but i don't want to run it once.
I want that the script runs when i push the button on and when i push the button off then the script stopts.
Running is no problem but stopping the script.
Killing a process is not a very elegant way to stop a script. Why not create a temp file before you enter the while true loop and within the loop build in a check if this file stil exist. If not --> exit the loop and script.
The stop command than simply have to trigger a script that removes the temp file created by the first script.
https://stackoverflow.com/questions/828 ... ile-exists
explains in quite a lot of detail howto check for the existence of a file
pascalbianca wrote: Saturday 17 February 2018 16:25 I'm sorry @waaren but i did read that link but still i don't know how to make it work in my code.
Can you help me please?
How do i make a temperyfile that contains my code?
Change script that starts the python to
#!/bin/sh
touch /tmp/AllowDomoticstestring
sudo PYTHONPATH=".:build/lib.linux-armv7l-2.7" python /home/pi/rpi_ws281x/python/examples/Domoticstestring.py
Change Domoticstestring.py to:
# NeoPixel library strandtest example
# Author: Tony DiCola ([email protected])
# Direct port of the Arduino NeoPixel library strandtest example.  Showcases
# various animations on a strip of NeoPixels.
import time
from neopixel import *
import argparse
import signal
import sys
import os.path
def signal_handler(signal, frame):
        colorWipe(strip, Color(0,0,0))
        sys.exit(0)
def opt_parse():
        parser = argparse.ArgumentParser()
        parser.add_argument('-c', action='store_true', help='clear the display on exit')
        args = parser.parse_args()
        if args.c:
                signal.signal(signal.SIGINT, signal_handler)
# LED strip configuration:
LED_COUNT      = 7      # Number of LED pixels.
LED_PIN        = 13      # GPIO pin connected to the pixels (18 uses PWM!).
#LED_PIN        = 10      # GPIO pin connected to the pixels (10 uses SPI /dev/spidev0.0).
LED_FREQ_HZ    = 800000  # LED signal frequency in hertz (usually 800khz)
LED_DMA        = 9      # DMA channel to use for generating signal (try 10)
LED_BRIGHTNESS = 20     # Set to 0 for darkest and 255 for brightest
LED_INVERT     = False   # True to invert the signal (when using NPN transistor level shift)
LED_CHANNEL    = 1       # set to '1' for GPIOs 13, 19, 41, 45 or 53  <<<staat op gpio 13
LED_STRIP      = ws.WS2811_STRIP_GRB   # Strip type and colour ordering
# Define functions which animate LEDs in various ways.
def colorWipe(strip, color, wait_ms=50):
	"""Wipe color across display a pixel at a time."""
	for i in range(strip.numPixels()):
		strip.setPixelColor(i, color)
		strip.show()
		time.sleep(wait_ms/1000.0)
def theaterChase(strip, color, wait_ms=50, iterations=10):
	"""Movie theater light style chaser animation."""
	for j in range(iterations):
		for q in range(3):
			for i in range(0, strip.numPixels(), 3):
				strip.setPixelColor(i+q, color)
			strip.show()
				strip.setPixelColor(i+q, 0)
def wheel(pos):
	"""Generate rainbow colors across 0-255 positions."""
	if pos < 85:
		return Color(pos * 3, 255 - pos * 3, 0)
	elif pos < 170:
		pos -= 85
		return Color(255 - pos * 3, 0, pos * 3)
	else:
		pos -= 170
		return Color(0, pos * 3, 255 - pos * 3)
def rainbow(strip, wait_ms=20, iterations=1):
	"""Draw rainbow that fades across all pixels at once."""
	for j in range(256*iterations):
			strip.setPixelColor(i, wheel((i+j) & 255))
		strip.show()
def rainbowCycle(strip, wait_ms=20, iterations=5):
	"""Draw rainbow that uniformly distributes itself across all pixels."""
			strip.setPixelColor(i, wheel((int(i * 256 / strip.numPixels()) + j) & 255))
		strip.show()
def theaterChaseRainbow(strip, wait_ms=50):
	"""Rainbow movie theater light style chaser animation."""
	for j in range(256):
		for q in range(3):
				strip.setPixelColor(i+q, wheel((i+j) % 255))
			strip.show()
# Main program logic follows:
if __name__ == '__main__':
        # Process arguments
        opt_parse()
	strip.begin()
	#print ('Press Ctrl-C to quit.')
	while os.path.isfile("/tmp/AllowDomoticstestring"):
		rainbow(strip)
Now if you want to stop Domoticstestring.py, you delete /tmp/AllowDomoticstestring
this can be done by a script or manually
