As its easier for me to sit with my laptop with Domoticz installed -- can I set everything up on my Windows 10 laptop - add all devices, create my custom blocky stuff - timers, etc..
Then when its all done export some file - and save it to Domoticz on my pi??
Thanks for the help!
Moving from Windows to Raspberry pi?
- Marci
- Domoticz version: 3.8153
Re: Moving from Windows to Raspberry pi?
This makes no sense. You access Domoticz via web browser. Accessing Domoticz hosted on your laptop vs accessing it hosted on a Pi is identical.
You’d still grab your laptop and head to http://pi.app.add.ress:8080/ in a web browser to set it all up... and use an SSH terminal (PuTTY) or VNC session from your laptop to the Pi to do any local configuration required.
Hello.
I agree with both answers. Nevertheless, I was on windows first, and the migration was easy : copy the database domoticz.db to the pi, copy all scripts and custom themes, and once on the pi, check all interfaces : no need to remove them, but only change the path from COM to ttyUSB.
Do all copy stuff when your domoticzs are stopped of course !
Send via Tapatalk
Send via Tapatalk
RPI3B (Domoticz 4.9700 + ~60 scripts) + RFXtrx433E (fw1020) + Z-Stick Gen5 + MySensors / RPI2B+ (RasPlex)
x1 Eth. wired tablet
x8 T/H Oregon / x1 T/H Bresser
x7 heaters / x2 QUBINO "Flush 1 relay"
x10 plugs / x15 contacts
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
