Aqara wall plug
Posted: Sunday 04 February 2018 15:45
by slydiman
I have installed the Aqara wall plug (ZigBee), model QBCZ11LM.
I don't see it in Domoticz.
It looks like that plug reports the following json:
{"cmd":"read_ack","model":"","sid":"***","short_id":***,"data":"{\"voltage\":3600}"}
Yes, the model is empty. I don't know how to correctly handle it.
Any ideas?
Re: Aqara wall plug
Posted: Sunday 04 February 2018 19:57
by ak97
I have same problem with new Aqara wall switches !
2018-02-03 17:31:56.907 XiaomiGateway: unhandled model:
2018-02-03 17:31:56.907 {"cmd":"read_ack","model":"","sid":"158d0001f99222","short_id":53738,"data":"{\"voltage\":3600,\"channel_0\":\"on\"}"}
2018-02-03 17:31:56.907 {"cmd":"read_ack","model":"","sid":"158d0001fa1960","short_id":53211,"data":"{\"voltage\":3600}"}
2018-02-03 17:31:56.907 {"cmd":"read_ack","model":"","sid":"158d0001fa18e7","short_id":12953,"data":"{\"voltage\":3600}"}
Re: Aqara wall plug
Posted: Monday 05 February 2018 9:51
by slydiman
My Aqara wall switches report the correct model. The only problem is voltage 3300 which means 110%.
{"cmd":"read_ack","model":"ctrl_neutral1","sid":"***","short_id":32104,"data":"{\"voltage\":3300,\"channel_0\":\"off\"}"}
{"cmd":"read_ack","model":"ctrl_neutral2","sid":"***","short_id":4179,"data":"{\"voltage\":3300,\"channel_0\":\"off\",\"channel_1\":\"off\"}"}
Probably the problem is Xiaomi Gateway firmware.
It looks like a bug in the developer protocol.
Let's wait for the firmware update...
Re: Aqara wall plug
Posted: Monday 05 February 2018 17:26
by ak97
I have two versions of Aqara wall switches:
1) without zero line (For example - QBKG04LM)
2) with zero line (For example - QBKG11LM)
Aqara switches without zero line (1) work correctly
But Aqara switches with zero line (2) have a support problem with domoticz
Re: Aqara wall plug
Posted: Saturday 10 February 2018 21:51
by Luis97
Same problem, the wall plug dont appear in the list.
Re: Aqara wall plug
Posted: Wednesday 14 February 2018 22:55
by Chatissimus
Hi Slydiman,
is your wall plug this one ?
https://xiaomi-mi.com/sockets-and-senso ... e-version/
Re: Aqara wall plug
Posted: Friday 16 February 2018 0:49
by slydiman
Yes, exactly.
Re: Aqara wall plug
Posted: Monday 14 May 2018 9:40
by vdbjimmy
Same problem here. I bought 2 wall plugs QBKG11LM and they are not visible in domoticz. I updated to the last beta version 3.9439 an it is still the same.
Have you succeeded in getting this verson of the wall plugs visible in Domoticz? Thank you.
Re: Aqara wall plug
Posted: Monday 14 May 2018 10:45
by DAVIZINHO
WOW!, not works??? :-(
i bought one the last week and i thought it will works :-(
Re: Aqara wall plug
Posted: Thursday 17 May 2018 21:51
by DAVIZINHO
Hello again.
I have this wall plug zigbee:
I installed it today and the domoticz detect the plug as switch type.
Works fine, no problem
But domoticz not detect the aditional device with the consumption kwh.
I have various zigbee plug, and allways detects 2 devices.
any idea??
Re: Aqara wall plug
Posted: Saturday 19 May 2018 6:54
by 1981nick1981
The problem is also with the new aqara cube. Domoticz recognizes the model but it is not visible between the devices.
