I would like to use my BME280 sensor. This sensor uses the I2C bus.
In settings => Hardware
I add a I2C sensor type ans I2C sensor BME280 as subtype.
and connect SDA, SCL, Vcc & GND pin
In the log I have
I2C Start HW witf ID: 12 Name: I2C_BME280 Address: 0 Port: undefined Invert:0
I2C_BME280: Worker started... Code: Select all
Error: I2C_BME280: Failed to open the i2c bus!...
Error: I2C_BME280: Check to see if you have a bus: undefined
Error: I2C_BME280: We might only be able to access this as root user
Error: I2C_BME280: Error opening device!... When I test this sensor with a python script, all is ok. I got tmp, Hum & baro correctly.
./bme280.py
Chip ID : 96
Version : 0
Temperature : 18.83 C
Pressure : 1020.56011709 hPa
Humidity : 57.5370776855 %
sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- 76 --
What's wrong with domoticz ??
