Get earthquake info
elmortero
Domoticz version: 3.9639
Get earthquake info
Post by elmortero »
Inspired by Python Plugin: Most recent Dutch earthquake I wanted to make something simular but with dzVents, and for any location worldwide.
This is what I came up with so far.
It requires a text sensor to write the output to.
--this scripts gets earthquake info from https://earthquake.usgs.gov for a defined area and then updates a text sensor with Magnitude and location
--it takes the first entry (= the most recent one) and therefore runs every ten minutes
--alternatively you could run it less frequently and search through the results and look for a specific location string
--the search area can be either be a rectangular (defined by the coordinates of the 4 corners) or circular zone (defined by the coordinates of the center
--and set the radius in km
--if you are curious, or to test it, you could remove the coordinates from the url and get worldwide info
		timer = { 'every 10 minutes'},
		httpResponses = { 'kwakeV2' } -- matches callback string below
	execute = function(domoticz, triggerItem)
-----use these variables if you want to define a square on the map for the detection area
local minlatitude = 35
local maxlatitude = 68
local minlongitude = -12
local maxlongitude = 35
-----use these variables if you want to define a radius
local latitude = 47
local longitude = 3
local maxradiuskm = 2000
--change the url in the openURL part below to this one if you want to define a radius around a central point
--https://earthquake.usgs.gov/fdsnws/event/1/query?format=geojson&limit=10&latitude='..latitude..'&longitude='..longitude..'&maxradiuskm='..maxradiuskm
function titleCase( first, rest )
   return first:upper()..rest:lower()
local sensor = domoticz.devices('Quakes')
local currInfo = tostring(sensor.text)
		if (triggerItem.isTimer) then
			domoticz.openURL({
				url = 'https://earthquake.usgs.gov/fdsnws/event/1/query?format=geojson&limit=10&minlatitude='..minlatitude..'&maxlatitude='..maxlatitude..'&minlongitude='..minlongitude..'&maxlongitude='..maxlongitude,
				method = 'GET',
				callback = 'kwakeV2'
		elseif (triggerItem.isHTTPResponse) then
	local response = triggerItem
		if (response.ok and response.isJSON) then
				local mgt = tonumber(response.json.features[1].properties.mag)
				local lugar = tostring(response.json.features[1].properties.place)
				local cuando = tostring(response.json.features[1].properties.time)
				local t = string.sub(cuando, 1,10)
		                local reString = os.date('%H:%M %a %d %B %Y', t)
				lugar = string.gsub(lugar, "(%a)([%w_']*)", titleCase)
				local qInfo = tostring('Magnitude of '.. mgt.. ' in '..lugar.. '  at '..reString)
						if qInfo ~= currInfo then
    						sensor.updateText(qInfo)
				print('**kwake failed to fetch info')
The detection area can be defined by either a rectangular or a circular zone.
In this script I get the latest event (and therefore it runs every 10 minutes)
