RFSwitches Plugin Help needed
Posted: Monday 29 January 2018 3:07
I tried to use the RFSwitches Plugin from https://www.domoticz.com/wiki/Plugins/RFSwitches.
Now i´m stuck at point 5.
Where should i enable the Plugin? I Don´t find anything where i can enable it.
Other Python Scripts works without problems.
5. ENABLE THE PLUGIN
Restart Domoticz, and under 'hardware' enable the RFSwitches plugin.
If you use different receive (rx) and transmit (tx) pins, enter the pin numbers here.
Restart Domoticz again, and now the plugin is active.Other Python Scripts works without problems.
