RFSwitches Plugin Help needed Topic is solved
matzeb74
Domoticz version: newest
Post by matzeb74 »
I tried to use the RFSwitches Plugin from https://www.domoticz.com/wiki/Plugins/RFSwitches.
Now i´m stuck at point 5.
5. ENABLE THE PLUGIN
Restart Domoticz, and under 'hardware' enable the RFSwitches plugin.
If you use different receive (rx) and transmit (tx) pins, enter the pin numbers here.
Restart Domoticz again, and now the plugin is active.
Where should i enable the Plugin? I Don´t find anything where i can enable it.
Other Python Scripts works without problems.
matzeb74
Re: RFSwitches Plugin Help needed
Post by matzeb74 »
Found the Solution.
Deinstalled Python 3.5 incl. Lib and installed Python 3.4. Now my Plugins are there.
blauwebuis
Domoticz version: current
Post by blauwebuis »
Glad to hear it. Is the plugin working ok for you?
antonis
Post by antonis »
Hello please can you post the commands to do this
