Milight t2 wall switch cct
Posted: Tuesday 23 January 2018 22:23
by 12345caravan
I'm having problems with my milight t2 wall switch adding to domoticz.
Accept new hardware, push button on wall switch, rflink/domoticz adds new device.
But when I use the new device nothing happens.
Domoticz only see the device switching off when i use the wall switch.
What goes wrong over here?
Re: Milight t2 wall switch cct
Posted: Sunday 04 February 2018 19:13
by 12345caravan
Nobody else using this switch?
Rflink is sending the following command when switching: 10;MiLightv1;02b2;01;0000;ON
Is this correct?
Just adding another switch T2 CCT, and thsi one isn't working either....
Rflink picks up the signal in domoticz, add device, but no response.
I can pair the bulbs in domoticz, but i want also use the switch.
Posted: Monday 05 March 2018 19:31
by tontze
Do you have "learn new device" enabled in domoticz settings, and enabled milight in rflink ? You need to also pair bulp with the switch.
Posted: Tuesday 06 March 2018 14:43
by 12345caravan
Yes did that, domoticz can see the new switch, but the rflink is sending a total different command as the wall switch, so this is not working.
I f I give the wall switch command through the rflink command line in domoticz, it is working.
Hope this will be supported in next rflink release.....
Posted: Wednesday 07 March 2018 0:07
by Stuntteam
Can you send me the commands that you logged?
Posted: Monday 23 April 2018 7:00
by tontze
Little late, but i did pair switch with bulbps, and thebn learned that switch press on domoticz.
