My domoticz monitors and controls my vacation home. Now I can not get into the domoticz. I have TeamViewer and on a PC so I can ping Domoticz, but get in to restart it, have tried Putty, advance IP scanner without successes, what to do?
Skickat från min iPhone med Tapatalk
I can ping but not connect to domoticz
- Siewert308SW
- Domoticz version: Stable
Re: I can ping but not connect to domoticz
I assume you could login remotely earlier?
Then wrong configuration aint what we are looking for.
On what system are you running.
I assume Windows as you are talking about TeamViewer.
It could be a network timeout, firewall suddenly blocking, system crash, sd/hdd crash or just not rebooted after powerloss.
You name it, we can't see that from here either.
As on what to do:
Nobody with a key in the neighborhood of your holiday house to take a look.
I hope your not running any important stuff, cause that's not very convenient to run such a system while nobody there for a long, long time and no way to get there asap.
This is one you have to sort out but getting there.
As for the future, if you insist on running a headless system over there then i would suggest to take precaution.
Like for example, background scripts to check in/outside ip and do something when lost.
Or a maybe a UPS so the system can run for a while when power is lost and reboot when it got power again.
good luck...
As on what to do:
good luck...
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
- DS923+ Docker
losholmen
Excuse me that I was unclear. Domoticz is running on an Rpi. with an Rtxtrx and a Z-wave USB device. Now I could get a neighbor to help me, with reboot
