Python Plugin: Most recent Dutch earthquake
Xorfor
Post by Xorfor »
Because it was so easy to program and a hot topic in the news in the Netherlands, I created a python plugin which displays information about the most recent earthquake in the Netherlands. This device displays:
- Date and time
- City (with link to the exact location in Google maps)
- Magnitude and type (tectonic or induced)
- Depth
Still beta, but plugin is available at https://github.com/Xorfor/Domoticz-Last ... ake-Plugin
blauwebuis
Domoticz version: current
Re: Python Plugin: Most recent Dutch earthquake
Post by blauwebuis »
Cool! Could there be a way for people in other countries to fill in their datasource?
EdwinK
Post by EdwinK »
Funny to see. The created map is that the exact location?
Xorfor
Post by Xorfor »
@blauwebuis,
I found an other source. My plan is to monitor earthquakes depending on the location set in Domoticz.
@EdwinK,
Yes, the map points to the location of the earthquake, which is calculated by different stations.
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
Thx...
Will try this one out.
Had hope the seismic sensor for the Fibaro Motion Sensor gets support in Domoticz.
Until then i will use this plugin to see if we got a earthquake due to the gasdrilling...
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
febalci
Post by febalci »
If you want an alternative, you can also check https://github.com/febalci/DomoticzEarthquake. It works a according to your location (in settings) and gets the info from seismicportal.com.
EdwinK
Post by EdwinK »
Atm I get the following error:
2018-01-20 17:18:02.572 Error: (Dutch Earthquakes): Async Read Exception: 104, Connection reset by peer
2018-01-20 17:18:02.594 Error: (Dutch Earthquakes): Socket Shutdown Error: 107, Transport endpoint is not connected
Could someone please shake Groningen a bit, so I can test if this is working now :)
Siewert308SW
@ EdwinK
Jumping, slamming doors and throwing my wife around.
Didn't help i think ;-)
@ febalci
thx...
Setup:
- DS923+ Docker
EdwinK
Post by EdwinK »
Siewert308SW wrote: Saturday 20 January 2018 17:30 @ EdwinK
Thanks for the help; unfortunately, it didn't help :(
:D
EdwinK
Post by EdwinK »
And now I get this error:
2018-01-20 19:27:08.259 Error: (Dutch Earthquakes) Device creation failed, Hardware/Unit combination (52:1) already exists in Domoticz.
Xorfor
Post by Xorfor »
Server seems to disconnect after some time. Changed the sequence of Connecting, get response and disconnect. This will solve the error messages about the connection.
For further testing, reinstall the plugin and reinstall the hardware. And then wait... :) .
I looked to some alternative sources, but the KNMI has the most actual and detailed information.
EdwinK
Post by EdwinK »
And again the same error
Siewert308SW
Haven't seen any errors since your last commit in github two days ago.
Plugin also updates without issues, this morning we a new earthquake and it's showed in the Domo widget...
Setup:
- DS923+ Docker
EdwinK
Post by EdwinK »
It all works now, still the error is there.
(Aardschokjes) Device creation failed, Hardware/Unit combination (57:1) already exists in Domoticz.
but as long as the script works, it's fine
Xorfor
Post by Xorfor »
Ok, finally a real test!!!
@EdwinK: I forgot a check in the code where I create devices. It is fixed now.
EdwinK
Post by EdwinK »
Okay. Can happen to everyone.
assenzuid
Post by assenzuid »
Great plugin, thanks.
Is it possible to get a notification (email or pushover) when there is a new earthquake logged?
Xorfor
Post by Xorfor »
@assenzuid,
Good point. Will think about this. Perhaps an extra alert device, which is switching on/off, when a new earthquake is logged?
assenzuid
Post by assenzuid »
Xorfor wrote: Tuesday 23 January 2018 19:39 @assenzuid,
:) will be nice
Derik
Post by Derik »
Nice job
works great..
Edit...
Perhaps an option to send a mail when there is a %^(%^( problem in Groningen..
