blockly else statement
nikos
Post by nikos »
I am new here, so pls excuse me if I am asking something already answered (I have not found an answer yet).
So my question is why is the "else' statement missing from the "if" options? Is it implemented by some other means??
Its presence would save us from an awful lot of repetitions.
misfit
Re: blockly else statement
Post by misfit »
You have that:
If you want to run statement if none of the 'else if' branch evaluates to true, then just put an always true condition (with a user variable) in a last 'else if' branch.
nikos
Post by nikos »
Thanks misfit, that's a good idea to get around the lack of the else statement. But why is it missing from the Domoticz blockly?
Xztraz
Post by Xztraz »
blockly else if is only used a a placeholder for multiple ifs. check the wiki out. quite explained there. http://www.domoticz.com/wiki/Blockly
There is some activity regarding "if else" if it's possible to make it a real else if.
i3laze
Post by i3laze »
misfit wrote: Sunday 21 January 2018 10:06 ..just put an always true condition (with a user variable) in a last 'else if' branch.
How can I get this ‘True’ block?
1=1? Example, plz.
mrf68
Post by mrf68 »
I tried this (Event - Blockly - All):
It doesn't work.
But the next one did (Event - Blockly - All):
The second one confirms that the value of the variable is correct.
Try to be as simple as possible with blockly's. One if and one do. Need something else done? Create another. It also helps troubleshooting.
And if you definitely need the else if, why not use the same components and use "is not" instead of "is"?
