triggerInfo.trigger for device change?
anasazi
Post by anasazi »
According to the dzVents wiki, triggerInfo.trigger only works for timer rules and for security state.
Is it possible to use this when devices changes also?
Check the example script below, is this possible?
	active = true,
		security = {
			domoticz.SECURITY_ARMEDAWAY,
			domoticz.SECURITY_DISARMED,
		devices = {
			'$Alarm - Detekterat',
	execute = function(domoticz, device, triggerInfo)
		if (triggerInfo.trigger == domoticz.SECURITY_ARMEDAWAY) then
			domoticz.devices('$Alarm - Delay Active').switchOn().forMin(1)
            		domoticz.devices('Siren').switchOn().forSec(1)
		elseif (triggerInfo.trigger == domoticz.SECURITY_DISARMED) then
			domoticz.devices('$Alarm - Siren Trigger').switchOff()
			domoticz.devices('$Alarm - Detekterat').switchOff()
			domoticz.devices('Siren').switchOff()
			domoticz.devices('$Alarm - Delay Active').switchOff()
		elseif (triggerInfo.trigger == '$Alarm - Detekterat') then
			if (device.state == 'On') then
				domoticz.devices('$Alarm - Siren Trigger').switchOn().afterSec(30)
emme
Domoticz version: latest
Re: triggerInfo.trigger for device change?
Post by emme »
Use device.name
"We always done this way"
SweetPants
Post by SweetPants »
anasazi wrote: Wednesday 17 January 2018 13:19 Hi,
	active = true,
		security = {
		devices = {
I'm using if (triggerinfo.type == domoticz.EVENT_TYPE_DEVICE) then with dzVentz 2.3.0
anasazi
Post by anasazi »
emme wrote: Wednesday 17 January 2018 13:57Use device.name
I have tried with device.name in combination with infoTrigger.info and it's woking, thanks!
Then I tried to add more devices and I added a wild-card device but this won't work when using device.name, see the example script below what I mean...
is this supposed to work or am I writing the script wrong?
	active = true,
		security = {
		devices = {
			'*dörren',
		elseif (device.name == '*dörren') then
dannybloe
Post by dannybloe »
Looks good to me, give it a try.. hire some burglars perhaps to help...
Can you change
into
elseif string.find(device.name,'dörren') ~= nil then
and report back what the result is ?
anasazi
Post by anasazi »
I will try with your recommendations this weekend.
