Timer
Posted: Friday 12 January 2018 9:15
I would like a timer function. so when switched on, timer switch off after set time.
Skickat från min iPhone med Tapatalk
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
What do you mean ?SweetPants wrote:trued Off delay on the switch?
Ok. But I dont know how it worksjvdz wrote:He meant: Did you try (Tried) the Off delay option of the Switch?
So in other words: The option is already there.
Jos
That is why i asked 'did you try the Off delay' (Switches->"Select your switch")->Edit->Off delay ( x sec)losholmen wrote: Saturday 13 January 2018 10:03Ok. But I dont know how it worksjvdz wrote:He meant: Did you try (Tried) the Off delay option of the Switch?
Jos
Aha ok thanks I will trySweetPants wrote:That is why i asked 'did you try the Off delay' (Switches->"Select your switch")->Edit->Off delay ( x sec)losholmen wrote: Saturday 13 January 2018 10:03Ok. But I dont know how it worksjvdz wrote:He meant: Did you try (Tried) the Off delay option of the Switch?
Jos
If you turn on the switch it will go off after x sec
