Timer
losholmen
Timer
Post by losholmen »
I would like a timer function. so when switched on, timer switch off after set time.
Skickat från min iPhone med Tapatalk
SweetPants
Re: Timer
Post by SweetPants »
trued Off delay on the switch?
losholmen
Re: Timer
Post by losholmen »
SweetPants wrote:trued Off delay on the switch?
What do you mean ?
jvdz
Domoticz version: 4.107
Re: Timer
Post by jvdz »
He meant: Did you try (Tried) the Off delay option of the Switch? ;)
So in other words: The option is already there.
Jos
losholmen
Re: Timer
Post by losholmen »
jvdz wrote:He meant: Did you try (Tried) the Off delay option of the Switch? ;)
Jos
Ok. But I dont know how it works
SweetPants
Re: Timer
losholmen wrote: Saturday 13 January 2018 10:03
Jos
That is why i asked 'did you try the Off delay' (Switches->"Select your switch")->Edit->Off delay ( x sec)
If you turn on the switch it will go off after x sec
losholmen
Re: Timer
Post by losholmen »
Jos
Aha ok thanks I will try
