Delayed Notification Script
Posted: Thursday 11 January 2018 19:10
I've used the script on the wiki and adjusted it slightly with the aim of sending a notification if the fridge door is open for two minutes.
The fridge door is connected via a Fibaro Universal Sensor to my z-wave network. Whilst the switch status changed the last seen time doesn't.
Because of this I am using variables in the script - Log is showing no errors but the script isn't doing anything that I can see, no variable updates or notifications.
I'm open to using dzVents rather than old Lua if it would be simpler.
Any help would be appreciated
function timedifference(s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
return difference
if (otherdevices['Fridge Door'] == 'Open' and uservariables['fridgedooropen']) == '0' then
commandArray['Variable:fridgedooropen'] = '1'
elseif (otherdevices['Fridge Door']) == 'Closed' then
commandArray['Variable:fridgedooropen'] = '0'
if (uservariables['fridgedooropen'] == '1' and uservariables['fridgedooralert'] == '0' and timedifference(uservariables_lastupdate['fridgedooropen']) > 120) then
commandArray['SendNotification']='Fridge Open for more than 2 minutes'
commandArray['Variable:fridgedooralert'] = '1'
elseif (uservariables['fridgedooropen'] == '0' and uservariables['fridgedooralert']) == '1' then
commandArray['Variable:fridgedooralert'] = '0'
