Delayed Notification Script
Jzjr
Domoticz version: 4.10717
Post by Jzjr »
I've used the script on the wiki and adjusted it slightly with the aim of sending a notification if the fridge door is open for two minutes.
The fridge door is connected via a Fibaro Universal Sensor to my z-wave network. Whilst the switch status changed the last seen time doesn't.
Because of this I am using variables in the script - Log is showing no errors but the script isn't doing anything that I can see, no variable updates or notifications.
I'm open to using dzVents rather than old Lua if it would be simpler.
Any help would be appreciated
function timedifference(s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   return difference
if (otherdevices['Fridge Door'] == 'Open' and uservariables['fridgedooropen']) == '0' then
   commandArray['Variable:fridgedooropen'] = '1'
elseif (otherdevices['Fridge Door']) == 'Closed' then
   commandArray['Variable:fridgedooropen'] = '0'
if (uservariables['fridgedooropen'] == '1' and uservariables['fridgedooralert'] == '0' and timedifference(uservariables_lastupdate['fridgedooropen']) > 120) then
   commandArray['SendNotification']='Fridge Open for more than 2 minutes'
   commandArray['Variable:fridgedooralert'] = '1'
elseif (uservariables['fridgedooropen'] == '0' and uservariables['fridgedooralert']) == '1' then
   commandArray['Variable:fridgedooralert'] = '0'
Fred Boniface
- Dell Optiplex 390 - Ubuntu Linux 18.04.01 LTS - Aeotec Z-Wave USB - RFXtrx433 - Hue Hub 2 - LGTV Plugin -
Hue Bulbs in every room, Temp Sensors on each floor, Temp-Monitoring Fridge, LightWaveRF 'Mood Switches'
