Is there any easy way to use timers with conditions?
Posted: Thursday 11 January 2018 17:51
by YellowSky
Hi everyone, i found the timers extremely useful.
However, if i want to use them with a condition it becomes some complicated.
A exemple a timer lauch the switch at 16:00 only if the temperature x is over 15°C
My current solution
- I can use cron to launch a python script with the condition before using json to lauch or not the timer. It is not convenient due to it can be done by user interface.
- I can use lua time script to launch each minute a script and if the time is ok and the conditions, the command array function could be used. The same issue as previsouly and the script is executed each minute while it needs only to be lauch once a day
Is there any simpler way to achieve this aim?
Re: Is there any easy way to use timers with conditions?
Posted: Thursday 11 January 2018 18:17
by Sandy
I'm new to domoticz so don't blame me if i'm wrong..
But couldnt you just use blockly like attached?
Posted: Thursday 11 January 2018 18:35
by Bikey
You can use a dummy switch which is set on/of at e.g. 16:00 hours.
Then with blocky or LUA you can check (on "device changed" only) when the dummy switch is activated if the temperature is over 15 degrees to activate the main switch.
Posted: Monday 15 January 2018 15:14
by YellowSky
Thank you for your suggestions.
I forget to mention the first solution you have proposed.
So there is not easier solution (i find these solutions are not quick to implement compared to the timers but i understand the limitations).
Once again thank you for these suggestions.
