Would be nice to be able to get the last seen info that can be read in hardware tab, under z-wave controller, for each included nodes, in Lua tables...
At the moment, this info can indeed be retrieved using :
http://localhost:8080/json.htm?type=ope ... odes&idx=2
And parsing json to get nodes LastUpdate info.
At 1st sight, this looks mis-labelled compared to a Lua otherdevices_lastupdate[device] info (i.e. last time a device changed state, not last seen by z-wave controller), but hereupper json API really returns last seen info.
An easier way to retrieve this (on a node idx/name basis, I suggest a otherdevices_lastseen[device]) without having to parse a global z-wave controller json response would help writing some device sanity check scripts.
BR.
Easy way to get z-wave node last seen info...
Ady92100
- Domoticz version: >V3.6796
Re: Easy way to get z-wave node last seen info...
+1
Synology DS212 + RFXTrx433 + AEon Stick S2
Oregon - Thgr122Nx / Chacon - module 1000w - détecteur de fumée 34131 / OWL -CM180 / Greenwave Multiprise
