pushover sound
Posted: Thursday 04 January 2018 22:21
by tiga
im testing out pushover and have the following problem:
in blockly when specifying the sound(in whatever prioroty), i get the "standard" sound on my Phone.
via the pushover-website sending a test message it works perfect!
how to solve this?
thank you!!
Re: pushover sound
Posted: Friday 05 January 2018 10:20
by Denny64
Is "Always use default tone" unchecked on the Pushover app?
For me it works properly. Domoticz 3.5877 on Rpi3.
Re: pushover sound
Posted: Friday 05 January 2018 10:23
by tiga
Yes it is unchecked
Re: pushover sound
Posted: Friday 05 January 2018 11:30
by Denny64
Which domoticz version do you have?
Has the same behavior in switch notification?
Re: pushover sound
Posted: Friday 05 January 2018 20:00
by tiga
Version: 3.8153
in switch notification i cannot chose a sound
Re: pushover sound
Posted: Friday 05 January 2018 20:25
by tiga
just did a test with sending a message in lua...same result
Re: pushover sound
Posted: Sunday 07 January 2018 8:42
by Denny64
Try to set two different sounds in the app, not stock sounds, (one for normal level and one for alarm) and try to see If Domoticz works well. Don't forget to check "Always use the default tone".
If It works, then go back, uncheck "Always use the default tone" and test If different stock sounds are correctly played with Domoticz.
Re: pushover sound
Posted: Sunday 14 October 2018 14:47
by George
Hi, Same problem here.
No matter what i tried, I alway get the default tone
(Even tried with a dummy switch):
- Event test schakelaar (Dummy Switch).JPG (33.1 KiB) Viewed 1450 times
Played a lot with settings in App, but cant solve the problem.
- settings 1.JPG (94.59 KiB) Viewed 1450 times
What am i doing wrong?
Raspberry Pi 3 Model B+ | Domoticz V4.9700 (Build Date: 2018-06-23 16:24:51) | Aeotec ZW090 Z-Stick Gen5 EU
Re: pushover sound
Posted: Sunday 14 October 2018 16:05
by George
Strange, but in case i choose:
Through subsystem "all", than the sound choice works.
But Through subsystem "pushover" I alway get the default sound and sound choice plays alway default sound, no matter what i choose.
- Through subsystem all sound choice works but default sound when subsystem is pushover.JPG (34.54 KiB) Viewed 1445 times
Ofcourse I do not want to send it to all subsystems! Only to pushover.
Re: pushover sound
Posted: Friday 09 November 2018 16:40
by tlkg
Any new developments on this?
I have the same problem, when Pushover is selected, notification sound is always the "Default" regardless of what is specified.
Re: pushover sound
Posted: Sunday 13 January 2019 20:34
by Plantje
I have a similar issue with the notification sound of Telegram.
For some reason every movement detected on my multi sensor is seen as a complete new category by my phone.
See this:
https://www.domoticz.com/forum/viewtopi ... 94#p203267
