Hi there,
I've an issue. I like to switch my light in the hall (Fibaro Dimmer2) on with a value of 20% for 1 minute when the PIR is activated between 00:00 and 07:00. So far so good.
The problem is that the dimmer keeps the value of 20% and when operating with the normal butten, the light is on for 20%.
What I like is to have the 20% value only from the script and when operating ' normal' it should have the value of 100%.
Is this possible?
Switch lights on PIR
- htilburgs
Hardware:
sion
Re: Switch lights on PIR
You could get the wall swith to trigger a group.
You can have just the hall light in it if you like, but then you can specify 100% from the wall switch.
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
- htilburgs
Tried it, but doesn't work: Skipping sensor 'Lamp gang' because this triggers another scene!
Hardware:
