How to create a dashboard virtual switch to disable/enable a saved blockly event?
edozwart
Post by edozwart »
hi everybody!
merry christmas to everybody! Can you help me out? I am trying to create a virtual switch on my "switches" panel (via hardware/dummy switch) to disable/enable my saved blockly event, but I don't know how to. My goal is that my script is normally enabled, the lights will be off at night, but it can happen that I want them enabled so easily want to disable the script (with my phone for example).
Please let me know if you know how to handle this.
thanks!
Egregius
Domoticz version: v2024.7
Re: How to create a dashboard virtual switch to disable/enable a saved blockly event?
Post by Egregius »
Create a dummy switch and check it's status in your script.
Something like:
if(switch['dummy']=='On') AND ...
edozwart
Post by edozwart »
hi Egregrius,
thanks for pointing me into the right direction! I can create that script using blockly for example but I don't know how to point to the saved event to disable that. Can you help me with that? Can that be done with blockly itself?
SweetPants
Post by SweetPants »
I'm not sure if this also counts for blockly events because I don't use that, but for LUA and dzVentz it works
/json.htm?type=events&param=updatestatus&eventid=21&eventstatus=0
use this JSON to get the list of events
/json.htm?type=events&param=list
edit: Should also work for Blockly
Last edited by SweetPants on Monday 25 December 2017 10:49, edited 2 times in total.
Egregius
Post by Egregius »
edozwart wrote: Monday 25 December 2017 9:09 hi Egregrius,
You don't disable your script, you just add another if statement so that the script is only executed when that switch is on.
edozwart
Post by edozwart »
hi sweet and Egregius,
thanks for the quick advice and helping me out! I used the tip from Egregius, works like a charme, thank you very much! Hereby my blockly script, maybe also handy for other people:
thanks guys!
Denny64
Domoticz version: 2023.1
Post by Denny64 »
In the last pass I would do:
Else if Time > 22:01 and Living Lamp Ceiling (3) = ON
Set Living Lamp Ceiling (3) = OFF
This to have more precision on the switch log and avoid to send frequent and useless commands on the z-wave network.
edozwart
Post by edozwart »
Thanks Denny64 for the tip, good point! I have updated my script!
love this forum!
SweetPants
Egregius wrote: Monday 25 December 2017 10:46
Be aware, your script is still fired. If it is time based every minute
edozwart
Post by edozwart »
hi! I know, I have ordered a dusk sensor to improve this and to avoid to use times.
matteos1
Post by matteos1 »
googlecustomer wrote:For making this just click on this link
http://www.digitaljournal.com/pr/3600586
Spam???
