isNightTime and isDayTime inverted?!
Freemann
Domoticz version: >=Béta
Post by Freemann »
Struggling for a few hours with this very simple function;
function IsDark()
            local dark
            if (domoticz.time.isNightTime ) then
                dark = "True"
                dark = "False"
            return dark
It constantly returns an inverted value.
Here(Netherlands) is night and the current script constantly returns; dark = False
Then I tested the same script but then with isDayTime and then it returns; dark = True
Added 2 notifies;
        function IsDark()
            local dark
            domoticz.notify("isNightTime: "..tostring(domoticz.time.isNightTime))
            domoticz.notify("isDayTime: "..tostring(domoticz.time.isDayTime))
                dark = "True"
                dark = "False"
            return dark
with the following result;
Screenshot - 23_12_2017 , 20_25_48.png (4.63 KiB) Viewed 1053 times
I'm I doing something wrong? Or .... ?
Domotica/graphs "freak" :)
NUC8i3BEH(8gb/250gb),
Lubuntu 19.04,
Aeotec Z-Stick S2(Gen5)
HarmonyElite
HUE(5 bulbs, 2 blooms)
NetAtmo(complete setup)
MiLight iboxV6(2 MiLightBulbs)
IP-Cam
https://www.frijduurzaam.nl
jvdz
Domoticz version: 4.107
Re: isNightTime and isDayTime inverted?!
Post by jvdz »
Are you running the latest Beta which has a confirmed DayTime/NightTime bug?
Jos
Freemann
Post by Freemann »
I'm running 3.8794 so the second best Beta there is.
ok... seeying it;
https://github.com/domoticz/domoticz/co ... 8f8abb3de7
My update policy is to update on an version diff of atleast 20 points, so I didn't look for this small update....
My bad...
Update is running :roll:
Lubuntu 19.04,
HarmonyElite
IP-Cam
Freemann
Post by Freemann »
OK, everything is working as expected. Thanks for you notice on the bug/update!
Lubuntu 19.04,
HarmonyElite
IP-Cam
