Hi All,
Does anyone has some thoughts about the following?
I have a mysensors node with a LCD screen (Nokia 5110) which works fine but I want to display some text from Domoticz. Therefore I create some V_TEXT/S_INFO children (one for each lcd line). These work ok as long as the mysensors node pulls the data from Domoticz.
I've read only pulling is possible and that's what I have done so far, but pulling several lcd lines every few seconds is generating unwanted traffic.
Therefore the question; Is it possible to push the data from Domoticz to mysensors, or is there a better method to omit high frequency pulling data?
Thanks in advance,
--Gerard
How to send text to sensor
- Domoticz version: latest-1
Re: How to send text to sensor
In case somebody is interested...
I solved it by adding and misusing an extra V_STATUS/S_BINARY device which is triggered from Domoticz by a small script and therefore the node "knows" it should request the TEXT data from Domoticz.
Not the most beautiful solution but it works for now. Hopefully in the near future Domoticz will send a message when a text device is updated.
Maybe I´m totally wrong (new to all of this^^), just an idea:
DZvents has a trigger for the device status. (https://www.domoticz.com/wiki/DzVents:_ ... ce_changes)
And you are able to send all kind of stuff to the devices using JSON (https://www.domoticz.com/wiki/Domoticz_ ... ext_sensor)
So maybe there´s a "clean" way to send your text message changes appropriate..
The problem is not updating the text value to or within Domoticz but sending the data to the (my)sensor.
It is a shortcoming of Domoticz. When the text value is updated Domoticz doesn't send the data to the mysensors gateway. However for a V_STATUS device Domoticz does send data to the gateway. That's why I use this device to inform the sensor so it can retrieve the text values from Domotics.
But, thanks for thinking with me
- Domoticz version: current
How do you change the text data in Domoticz? I have a MySensors node that periodically checks domoticz for a password. But I don't know how to change that text value inside domoticz.
I tried creating a user variable and then setting that variable as the text via Blockly. But blockly says I can only read the value of a utility, and not set it
- emme
I'm well interested into the mysensor LCD and how you create it...
I'm willing to create an epaper display with the status of the system (a rolling text containing some information pulled or pushed from domoticz)
but so far I has no idea how to compute it...
Would you mind to share the sketch with few pics of your device?
ciao
M
ciao
M
"We always done this way"
Buona sera,
Sure, I would happily share some info on how I did this. It can take a while to gather things readable together. I'm starting up after some weeks of illness so the code is as messy as me.....
What I did is on the Mysensors side:
- created some V_TEXT/S_INFO children (I use 3 lcd lines but you could use more or less)
- created 1 V_STATUS/S_BINARY child (This is used to trigger the ms node to request the V_TEXT data)
- Listen for message.type == V_STATUS and message.sensor is the correct one
- If message.getbool() == true then start requesting lcd sensors from domoticz like request(id,V_TEXT)
- Listen for lcd message.sensor id's and do a message.getString()
- If lcd updates are received, update the lcd
- After updating the lcd I send a message to domoticz to set the trigger switch to off
On Domoticz, with a small lua script update the text devices with the required text. I extract some temperature, humidity and other weather info and put it on the text devices. When some data is changed I set the (trigger) switch to on so that the Mysensors node is informed so that it can request the data.
Be aware that if you use the nrf24 the maximum message size is rather small (a bit less than 32 bytes) so you might use some more devices or use a buffer on the Mysensors node to shift in the data.
So hopefully you can do something with this info. Otherwise I can make in the future a simple proof of concept and present all the code here.
--Gerard
--Gerard
Would you mind sharing your code? Sounds like you have it nailed
No time to optimize the code but here it is...
On the Arduino Nano the following code is running:
On Domoticz this code creates the following devices:
Within Domoticz the following event is running (no dzVents yet, someone has to rewrite this part)
Just for illustration, the devices on the domo panel
Hopefully this helps a bit.
--Gerard
File: LCDemo A Mysensors demo project for interaction with Domoticz
Hardware: Arduino NANO
Functions: Show 3 lines on LCD (Nokia 5110) with text from Domoticz
Control backlight of LCD by Domoticz switch
PIR sensor on interrupt pin as motion sensor on Domoticz
LDR sensor on analog port to show light level on Domoticz
obsolete: change contrast of LCD with Domoticz slider (does work but not usefull)
Uses Domoticz switch to trigger LCD updates (CHILD_ID_STAT)
By: Gerard - 2017
#define SKETCH_NAME "LCDemo"
#define SKETCH_VERSION "1.8.2"
#define MESSAGEWAIT 500
// Nokia 5110 LCD - 84 x 48 pixels
#include <LCD5110_Graph.h>
//LCD5110 myGLCD(7, 6, 5, 3, 4);
LCD5110 myGLCD(7, 6, 5, 18, 4); // pin 3 has moved to 18(A5) because we need interrupt pin 3
extern uint8_t SmallFont[]; // 6x8 pixels max 14 chars x 5 lines
extern unsigned char TinyFont[]; // 4x6 pixels max 21 chars X lines
String lcdLine[5];
#define PIR_PIN 3 // PIR sensor
#define LIGHT_SENSOR_ANALOG_PIN A0 // LDR sensor
#define RELAY_PIN 8 // Actually not a relay anymore but the LCD backlight now
#define RELAY_ON 1 // GPIO value to write to turn on attached relay
#define RELAY_OFF 0 // GPIO value to write to turn off attached relay
#define MY_DEBUG
#define MY_RADIO_NRF24
#define MY_NODE_ID 10
//#define MY_REPEATER_FEATURE
#include <MySensors.h>
#define CHILD_ID_RELAY 0
#define CHILD_ID_LCD1 1 // LCD line 1
#define CHILD_ID_LCD2 2 // LCD line 2
#define CHILD_ID_LCD3 3 // LCD line 3
#define CHILD_ID_DIMMER 4
#define CHILD_ID_LDR 5
#define CHILD_ID_PIR 6
#define CHILD_ID_STAT 7 // test with v_status s_binary to trigger request lcd line info
MyMessage textMsg1(CHILD_ID_LCD1, V_TEXT);
MyMessage textMsg2(CHILD_ID_LCD2, V_TEXT);
MyMessage textMsg3(CHILD_ID_LCD3, V_TEXT);
MyMessage dimmerMsg(CHILD_ID_DIMMER, V_DIMMER);
MyMessage lightMsg(CHILD_ID_DIMMER, V_LIGHT);
MyMessage LdrMsg(CHILD_ID_LDR, V_LIGHT_LEVEL);
MyMessage PirMsg(CHILD_ID_PIR, V_TRIPPED);
MyMessage StatMsg(CHILD_ID_STAT, V_STATUS);
static const uint64_t UPDATE_INTERVAL = 60000;
unsigned long currentMillis = 0;
volatile unsigned long previousMillis = 0;
volatile bool pirEvent = true;
static int16_t currentLevel = 0; // Current dim level...
bool lcdUpdate = false;
bool lcdUpdate1 = false;
bool lcdUpdate2 = false;
bool lcdUpdate3 = false;
bool lastPir = false;
int LightLevel = 0;
int PreviousLightLevel = 0;
bool domoTrigger = false;
bool runOnce = true;
void before()
pinMode(RELAY_PIN, OUTPUT);
//digitalWrite(RELAY_PIN, loadState(sensor)?RELAY_ON:RELAY_OFF);
digitalWrite(RELAY_PIN, RELAY_ON); // for now force backlight on
void setup()
lcdLine[0][0] = 0;
lcdLine[0] = SKETCH_NAME;
lcdLine[0].concat(" ");
lcdLine[0].concat(SKETCH_VERSION);
lcdLine[1] = "--------------";
lcdLine[2] = "--------------";
lcdLine[3] = "--------------";
lcdLine[4] = "..............";
myGLCD.InitLCD();
myGLCD.setFont(SmallFont);
myGLCD.clrScr();
myGLCD.print(lcdLine[0], CENTER, 0);
myGLCD.update();
myGLCD.setContrast(70);
request(CHILD_ID_RELAY, V_STATUS);
wait(MESSAGEWAIT);
request(CHILD_ID_DIMMER, V_DIMMER );
wait(MESSAGEWAIT);
request(CHILD_ID_LCD1, V_TEXT);
wait(MESSAGEWAIT);
request(CHILD_ID_LCD2, V_TEXT);
wait(MESSAGEWAIT);
request(CHILD_ID_LCD3, V_TEXT);
pinMode(PIR_PIN, INPUT);
attachInterrupt(digitalPinToInterrupt(PIR_PIN), pirChange, CHANGE);
pinMode(LIGHT_SENSOR_ANALOG_PIN, INPUT_PULLUP);
LightLevel = (1023 - analogRead(LIGHT_SENSOR_ANALOG_PIN)) / 10.23;
void presentation()
// Send the sketch version information to the gateway and Controller
sendSketchInfo(SKETCH_NAME, SKETCH_VERSION, true);
Serial.print(F("NodeID: "));
Serial.println(getNodeId());
present(CHILD_ID_RELAY, S_BINARY, "RelayP8");
wait(MESSAGEWAIT);
present(CHILD_ID_LCD1, S_INFO, "LCD_line1", true); // new S_type 20150905 (not known by domoticz)
wait(MESSAGEWAIT);
present(CHILD_ID_LCD2, S_INFO, "LCD_line2", true);
wait(MESSAGEWAIT);
present(CHILD_ID_LCD3, S_INFO, "LCD_line3", true);
wait(MESSAGEWAIT);
present(CHILD_ID_DIMMER, S_DIMMER );
wait(MESSAGEWAIT);
present(CHILD_ID_LDR, S_LIGHT_LEVEL, "LDR");
wait(MESSAGEWAIT);
present(CHILD_ID_PIR, S_MOTION, "PIR");
wait(MESSAGEWAIT);
present(CHILD_ID_STAT, S_BINARY, "LCD_Trigger");
void loop()
if (runOnce) {
send(textMsg1.setSensor(CHILD_ID_LCD1).set("lcd1 waiting")); // initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
wait(MESSAGEWAIT);
send(textMsg2.setSensor(CHILD_ID_LCD2).set("lcd2 waiting"));
wait(MESSAGEWAIT);
send(textMsg3.setSensor(CHILD_ID_LCD3).set("lcd3 waiting"));
runOnce = false;
if (lcdUpdate1 && lcdUpdate2 && lcdUpdate3) { // check if all 3 lcd lines are received before update entire display
lcdUpdate = true;
unsigned long currentMillis = millis();
if ((currentMillis - previousMillis >= UPDATE_INTERVAL) || pirEvent || domoTrigger || lcdUpdate) {
previousMillis = currentMillis;
// Handle PIR sensor
if (pirEvent) {
bool pirTripped = digitalRead(PIR_PIN) == HIGH; // reading twice has not much use. To be optimised...
Serial.print("PIR:"); Serial.println(pirTripped);
myGLCD.invert(pirTripped);
send(PirMsg.setSensor(CHILD_ID_PIR).set(pirTripped ? "1" : "0"));
pirEvent = false;
// Handle LCD triggers
if (domoTrigger) { // evidently received a trigger from Domoticz so send requests until all lines are received
if (lcdUpdate1 == false) {
wait(MESSAGEWAIT);
if (lcdUpdate2 == false) {
wait(MESSAGEWAIT);
if (lcdUpdate3 == false) {
wait(MESSAGEWAIT);
send(StatMsg.setSensor(CHILD_ID_STAT).set("0")); // reset trigger switch on Domoticz
// Handle LDR sensor data
Serial.print("Lux:"); Serial.println(LightLevel);
if (LightLevel != PreviousLightLevel) {
send(LdrMsg.setSensor(CHILD_ID_LDR).set(LightLevel));
lcdLine[4] = "Lux: ";
lcdLine[4].concat(LightLevel);
lcdUpdate = true;
PreviousLightLevel = LightLevel;
// Update the LCD if required
if (lcdUpdate ) {
myGLCD.clrScr();
myGLCD.print(lcdLine[0], LEFT, 0);
myGLCD.print(lcdLine[1], LEFT, 10);
myGLCD.print(lcdLine[2], LEFT, 20);
myGLCD.print(lcdLine[3], LEFT, 30);
myGLCD.print(lcdLine[4], LEFT, 40);
myGLCD.update();
lcdUpdate = false;
lcdUpdate1 = false; lcdUpdate2 = false; lcdUpdate3 = false;
// PIR interrupt routine
void pirChange()
pirEvent = true;
previousMillis = 0;
// Callback routine for receiving messages
void receive(const MyMessage & message)
#ifdef MY_DEBUG
Serial.print("RX:"); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());
#endif
// check incoming LCD line text
switch (message.sensor) {
case 1:
lcdLine[1] = message.getString();
lcdUpdate1 = true;
break;
case 2:
lcdLine[2] = message.getString();
lcdUpdate2 = true;
break;
case 3:
lcdLine[3] = message.getString();
lcdUpdate3 = true;
break;
default:
//lcdLine[4] = message.getString();
break;
// Check for Trigger
if ((message.type == V_STATUS) and (message.sensor == CHILD_ID_STAT)) {
// force lcd line get from domoticz update
if (message.getBool() == true) {
domoTrigger = true;
Serial.println("lcd update from Domoticz");
// Backlight on or off
if ((message.type == V_STATUS) and (message.sensor == CHILD_ID_RELAY)) {
// Change relay state
digitalWrite(RELAY_PIN, message.getBool() ? RELAY_ON : RELAY_OFF);
// Store state in eeprom
//saveState(message.sensor, message.getBool());
// Write some debug info
Serial.print("Incoming change for sensor:");
Serial.print(", New status: ");
Serial.println(message.getBool());
// Obsolete code and to be removed. Was used to control LCD contrast.
if (message.type == V_LIGHT || message.type == V_DIMMER) {
// Retrieve the power or dim level from the incoming request message
int requestedLevel = atoi( message.data ) ;
// Adjust incoming level if this is a V_LIGHT variable update [0 == off, 1 == on]
requestedLevel *= ( message.type == V_LIGHT ? 80 : 1 );
// Clip incoming level to valid range of 0 to 100 (50-80)
requestedLevel = requestedLevel > 80 ? 80 : requestedLevel;
requestedLevel = requestedLevel < 0 ? 50 : requestedLevel;
Serial.print( "Changing level to " );
Serial.print( requestedLevel );
Serial.print( ", from " );
Serial.println( currentLevel );
//fadeToLevel( requestedLevel );
//myGLCD.setContrast(requestedLevel);
// Inform the gateway of the current DimmableLED's SwitchPower1 and LoadLevelStatus value...
send(lightMsg.set(currentLevel > 0));
// hek comment: Is this really nessesary?
send( dimmerMsg.set(currentLevel) );
local m = os.date('%M')
if (m % 5 == 0) then
print("The 5 minute script interval reached")
s = otherdevices_lastupdate['LCD_Trigger']
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
difference = (os.difftime (t1, t2))
sTemp, sHumidity = otherdevices_svalues['msTempHum']:match("([^;]+);([^;]+)")
sSchuurTemp, sSchuurHumidity = otherdevices_svalues['Buienradar - Barometer']:match("([^;]+);([^;]+)")
regen = math.floor(tonumber(otherdevices_svalues['Rain2Come - Rain2Come']))
ttlcd1 = otherdevices_idx['LCD_line1']
ttlcd2 = otherdevices_idx['LCD_line2']
ttlcd3 = otherdevices_idx['LCD_line3']
ttTrig = otherdevices_idx['LCD_Trigger']
commandArray[1] = { ['UpdateDevice'] = ttlcd1..'|0|'..'Regen: '..regen }
commandArray[2] = { ['UpdateDevice'] = ttlcd2..'|0|'..'T:'..sSchuurTemp..' H:'..sSchuurHumidity..'%'}
commandArray[3] = { ['UpdateDevice'] = ttlcd3..'|0|'..'T:'..sTemp..' H:'..sHumidity..'%' }
if (difference > 120) then
commandArray[4] = { ['LCD_Trigger'] = "On" }
--Gerard
