no ID, no TYPE for ZWave devices (ID = 0x0000, TYPE = 0x0000)
Posted: Tuesday 19 December 2017 12:55
by altarus1
I've used domoticz since one year on raspberry but I would migrate this on linux.
I've installed domoticz on fresh linux following wiki page for linux install (http://www.domoticz.com/wiki/Linux)
Please note that OS is a virtual machine, but USB device (RFXtrx433 and ZWave dongle are mounted and seen by system).
After install, I've restored domoticz db to new system saved from the raspberry
The install seems to be fine, Domoticz runs normally and there is no pb with RFXcom, script... . But, except zwave controller (Aetoec Z-Stick Gen5), all devices haven't IDs, nor TYPEs. And so, none values are recorded (devices seems to be unseen)
Clipboard 1.jpg (154.62 KiB) Viewed 2737 times
Clipboard 2.jpg (192.56 KiB) Viewed 2737 times
try searching solution in this forum, found some topics wich describe sames issues with recent release of Domoticz, then I have done new compil from last stable release (v3.8153) which is the same release of my Domoticz install on Raspberry.
I also try "Refresh Node Info" from OZW control panel but didn't resolve issue (give ERROR: Dropping command, expected response not received...)
Nodes topology seem to be ok
Someone could help me ?
Re: no ID, no TYPE for ZWave devices (ID = 0x0000, TYPE = 0x0000)
Posted: Tuesday 19 December 2017 13:03
by philchillbill
I had it in the past and it magically stopped happening a while back. The temporary fix at the time was to delete the ozwcpxxx xml file in your /Config directory and reboot.
Posted: Tuesday 19 December 2017 13:18
by altarus1
Thank you philchillbill for your answer.
I try it by renaming zwcfg_XXX.xml file (in Config dir), then reboot. After reboot, device aren't still not identified. A new xml config file is created, I open it, ID and TYPE are set to 0
Posted: Tuesday 19 December 2017 13:38
by ropske
Your device_manufacturer.xml is not up to date i think
Posted: Tuesday 19 December 2017 14:06
by altarus1
ropske wrote: Tuesday 19 December 2017 13:38 Your device_manufacturer.xml is not up to date i think
I didn't find any device_manufacturer.xml file, did you mean manufacturer_specific.xml in Config dir ? I open it, and it seem to include my devices (note that I didn't have exotic devices, only Aeotec multisensor and fibaro plugs)
If not, where can I find this file, and how can I update it ?
Posted: Monday 25 December 2017 23:15
by hestia
hello
I've the same issue when including new z-wave hardware, no device are visible.
I had a beta version about 1 month old, as it didn't work, I've upgraded today with Version: 3.8796. And it's the same :-(
Any other ideas? Isn't it a bug of this beta?
Posted: Saturday 30 December 2017 23:31
by hestia
hestia wrote: Monday 25 December 2017 23:15 hello
some news:
the case that doesn't work is when I try to include a device with the Z-wave stick( Aeotec ZW090 Z-Stick Gen5 EU) unplugged from the domoticz server (PI)
When I include it near the PI and with the Z-wave stick plugged it works fine!
Posted: Saturday 15 December 2018 20:50
by GSV3Miac
That just solved it for me too, with z-stick and aeotec multi sensor. Apparently the 'get device info' receipt/response was harder to achieve than the normal data transfer ( you can see ozw try, and fail, at 20m range).
