JSON + MQTT
ddragas
JSON + MQTT
Post by ddragas »
Hi all
I'm having problem with publishing MQTT message to Domoticz and running script that is behind that switch.
Switch type is Selector Switch (multiple values) that behind every value has a script that is executed. This switch normally works trough Domoticz interface and script is being triggered, and this is same action I need to be executed when sending JSON trough MQTT.
this is JSON which I'm executing when I want heat to turn off
mosquitto_pub -t "domoticz/in" -m '{ "command": "udevice", "idx": 66, "nvalue": 0, "svalue1": "0" }'
and after executing code from above I get strange behaviour.
Both buttons are selected as active (Off and Heat)
https://ibb.co/mYe6Zm
when I click button from domoticz interface, in mqtt subscribe I get this JSON
domoticz/out {
   "Battery" : 255,
   "LevelActions" : "script%3A///home/pi/domoticz/scripts/aircon.php%201|script%3A///home/pi/domoticz/scripts/aircon.php%20aircon_on|script%3A///home/pi/domoticz/scripts/aircon.php%20aircon_mode_dry|script%3A///home/pi/domoticz/scripts/aircon.php%20aircon_mode_cool|script%3A///home/pi/domoticz/scripts/aircon.php%20aircon_mode_heat",
   "LevelNames" : "Off|On|Dry|Cool|Heat",
   "LevelOffHidden" : "false",
   "RSSI" : 12,
   "SelectorStyle" : "0",
   "description" : "",
   "dtype" : "Light/Switch",
   "id" : "00014092",
   "idx" : 66,
   "name" : "Air Condition",
   "nvalue" : 0,
   "stype" : "Selector Switch",
   "svalue1" : "0",
   "switchType" : "Selector",
   "unit" : 1
what am I doing wrong?
thnx in advance
jvdz
Domoticz version: 4.107
Re: JSON + MQTT
Post by jvdz »
Doesn't this Selector switch also act as an DImmer which requires an On;Off or Set Level command?
I am not that familiar with MQTT, but is it "svalue1" or "svalue"?
Something like:
mosquitto_pub -t "domoticz/in" -m '{ "command": "udevice", "idx": 66, "nvalue": 0, "svalue": "Off" }'
mosquitto_pub -t "domoticz/in" -m '{ "command": "udevice", "idx": 66, "nvalue": 10, "svalue": "Set%20Level" }
Jos
ddragas
Re: JSON + MQTT
Post by ddragas »
thnx for your reply … but still without success … I really need to sort out how to properly trigger switch …
ddragas
Re: JSON + MQTT
Post by ddragas »
I've managed to trigger switch with command
mosquitto_pub -t "domoticz/in" -m '{"command": "switchlight", "idx": 66, "switchcmd": "Set Level", "level":"40"}'
if some else need it
Cheers and thnx for help
