fibaro fgs-213 ZW5 not able to control in Domoticz
SVdHeyden
Domoticz version: 4.10717
Post by SVdHeyden »
System configuration:
Cubietruck with OS Debian GNU/Linux 8.10 (jessie)
Domotics version 3.8153 Build Hash: 494fff7
In the Zwave setup the following is found concerning the FGS213
node id      Name      Description                   Manufacture     id       Type     Last seen             polling
029 (0x1d) Badkamer_Ventilator FIBARO System FGS213 Switch FIBARO System 0x1000 0x0403 2017-12-14 19:27:48 No
According to me everything is recognised well however I can't control the FGS213 switch.. When I change the status of the FGS213 with the with the connected switch the status is updated in web page but when I change the status in the web page nothing happens.
under the devices the switch is given as follow:
seen in Devices
seen in Devices
The icon is not indicating a switch but rather something measuring power
In attach the z-wave cache file can be found.
When I want to control the switch with the blockly script
Blockly script
Blockly script
the following is written in the log
The condition is made with a Fibaro FGBS001 universal sensor which is working fine.
 2017-12-14 21:04:11.333 EventSystem: Event triggered: Side_Camera_Alert_1
 2017-12-14 21:04:11.337 (Z-Wave ) Light/Switch (Side_Camera_Alert)
 2017-12-14 21:04:11.345 OpenZWave: Domoticz has send a Switch command!, Level: 255, NodeID: 29(0x1d)
 2017-12-14 21:04:11.367 (Z-Wave ) Light/Switch (Badkamer_Ventilator)
 2017-12-14 21:04:15.943 EventSystem: Event triggered: Side_Camera_Alert_2
 2017-12-14 21:04:15.947 (Z-Wave ) Light/Switch (Side_Camera_Alert)
 2017-12-14 21:04:15.981 OpenZWave: Domoticz has send a Switch command!, Level: 0, NodeID: 29 (0x1d)
 2017-12-14 21:04:16.008 (Z-Wave ) Light/Switch (Badkamer_Ventilator)
In the log the device is controlled with dim values instead of on/off.
At the end the switch is not changing state.
When in the 'OpenZWave Control Panel'
I'm able to control the switch.
So I'm not able to control the switch fgs-213 via Domoticz.
Can someone give some advice how to get this working?
zwcfg_0x0184dea9.xml
(334.01 KiB) Downloaded 121 times
SVdHeyden
Re: fibaro fgs-213 ZW5 not able to control in Domoticz
Post by SVdHeyden »
Somebody out there to explain how to get control over the fgs-213?
Many thanks
SVdHeyden
Post by SVdHeyden »
No solution for this issue?
Can this be solved by controlling the device via json interface?
for those listening thanks for replying....
Bostjan
Post by Bostjan »
I had a similar problem with similar symptoms a while ago. It could be the problem that your device hasn't been seen by controller for a while and therefore controller moved it to it's "failed node list" (OZW also has such list). Depending on the exact situation solution could be to try execute "Has node failed" and/or "Replace dead node" in OZW control panel. Finally you could re-add device to network.
BTW, you were also attaching image where you show device list with device 29. This is wrong as you've confused device IDX with zwave node ID, which are two different things. Screenshot you posted is for node 0x12, as seen from device ID 0001204
Bostjan
Post by Bostjan »
Hmm, I've update for my previous post. After I re-included my FGS-213 it worked perfectly, sending On/Off command. Then I restarted Domoticz and had exactly the same symptoms, Domoticz send level command and consequently module did not respond to command. Further I restarted Domoticz again and started to work again, sending On/Off command and module responded.
This exceeded my knowledge and experience and have no idea what is going on :shock:
SVdHeyden
Post by SVdHeyden »
When I removed the FGS213.xml from the directory domoticz/Config/fibaro and rebuild the zwcfg_0x******.xml file then the FGS-213 is working fine. Now I have to compare the original FGS213.xml with what is currently in zwcfg_0x******.xml to see what is causing the incompatibility.
Cosmo88
Post by Cosmo88 »
You can't stop, for instance, web site indexing robots from trying to figure-out is there is something to index!
รูเล็ต
Darralius
Post by Darralius »
Did you find a solution to this at all? I am having the same problem.
Initially I had trouble including the device. Domoticz and Open Zwave both reported unknown device with a type and Id code. I checked the manufacture_specific.xml file and found that my switch was reporting the same type but different ID (3000 instead of 2000 or 1000) to the listed FGS-213. I added a line to direct this switch type and ID to the same FGS-213 config file as the other types. I assume this a region thing, AU region device.
I can manually switch the switch from the open zwave control panel and it works correctly. When I select auto add on the switch page in Domoticz and manually flick the switch it registers and adds its correctly. Changing the state of this switch in Domoticz makes no physical change.
Logs show the user request etc as usual.
2018-04-07 16:24:16.918 User: T initiated a switch command (142/Garage Lights/On)
2018-04-07 16:24:16.918 OpenZWave: Domoticz has send a Switch command!, Level: 255, NodeID: 24 (0x18)
2018-04-07 16:24:16.932 (Aeotech) Light/Switch (Garage Lights)
2018-04-07 16:24:18.963 User: T initiated a switch command (142/Garage Lights/Off)
2018-04-07 16:24:18.964 OpenZWave: Domoticz has send a Switch command!, Level: 0, NodeID: 24 (0x18)
Maes
Post by Maes »
I had the same problem.
I just did what SVdHeyden said and it works:
Remove FGS213.xml from the directory domoticz/Config/fibaro and rebuild the zwcfg_0x******.xml file then the FGS-213 is working fine.
The only problem is that when you do this, domoticz won't show any parameters for the node anymore. But I couldn't care less about those.
Darralius
Post by Darralius »
Thanks,
I stopped Domoticz, renamed the fgs-213.xml file and the zwcfg_0x******.xml file, then restarted Domoticz.
It has auto built the zwcfg_0x******.xml file.
Still can't control the switch, will keep messing with it.
