I am a bit of a newbee to Domoticz on a PI3, config is:
Domo Version 3.8153 (July 30h 2017)
PI3, running Raspian 4.9.67-v7+
I have the Razberry2 module set and it's configured according to the setup guide here:
viewtopic.php?f=28&t=15795&p=117355#p117527
The card seems to be fine, the SETUP button is blue, I can even see devices (unknown) besids the controller:
OpenZWave USB Version: 1.4-2501-g5af6780-dirty
024 (0x18) Unknown 0x0000 0x0000 2017-12-13 21:19:35 No Heal node
022 (0x16) Unknown 0x0000 0x0000 2017-12-13 21:19:35 No Heal node
012 (0x0c) Unknown 0x0000 0x0000 2017-12-13 21:19:35 No Heal node
001 (0x01) Controller Z-Wave.Me RaZberry Controller 2016 ZWave+ Z-Wave.Me 0x0002 0x0400 2017-12-13 21:19:35 No Heal node
Now I have a Fibaro FGMS-001 as a "test" device, a motion sensor which should be added as first node.
I tried to add this device in HOMEE (my other controller) and it worked fine - it shows motion, temp & stuff. I have then excluded the node from HOMEE again, deleted it in the config, and shut down HOMEE so it's not interferring with the PI3.
Then I tried to add the node in DM but it's not found. The red / green led on the Razberry2 board is on but the node is not added.
Maybe you guys can give me an idea what I am doing wrong...
Many thanks!
Razberry2 - Can't add device (e.g. Fibaro FGMS-001
Re: Razberry2 - Can't add device (e.g. Fibaro FGMS-001
Did you solved that problem? I have the same issue.
Tomek
Tomek
tontze
- Domoticz version: Beta Ch
I have this fibaro added on my system, dont remember any problems when adding it. I quess u have "allow new devices" enabled in domoticz ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
