FIBARO FGT-001 - The Heat Controller Radiator Thermostat
Posted: Tuesday 12 December 2017 11:08
by lcervo
I am running domoticz (Version 3.8153) on a rasperry pi 3 with an Aeotec ZW090 Z-Stick Gen5 EU (OpenZWave USB Version: 1.4-2501-g5af6780-dirty).
I bought 2 new Fibaro radiator valves (https://www.fibaro.com/en/products/the-heat-controller/). Their "code" is FGT-001 (https://manuals.fibaro.com/content/manu ... T-v1.0.pdf).
This is what I see from the hardware
and device pages in domoticz:
How do I make it work? Has anyone worked it out yet? I checked the openzwave github page https://github.com/OpenZWave/open-zwave ... fig/fibaro but the config is not there. Is there any guide I can read to create an xml for this new device?
Thanks,
L.
Re: FIBARO FGT-001 - The Heat Controller Radiator Thermostat
Posted: Tuesday 12 December 2017 14:55
by samuelAN
Hello !
I also have a gen5 stick and I will soon get my FGT-001 valves.
I am also highly interested if anyone of you have a solution or a guide to add this new device in OpenZwave configuration !!
Thanks,
Samuel.
Posted: Tuesday 12 December 2017 20:22
by fr3sh
I'm also interested for this one :)
My post:
viewtopic.php?f=24&t=20851
Posted: Thursday 14 December 2017 9:27
by samuelAN
I have found this tutorial : https://github.com/OpenZWave/open-zwave ... ng-Devices
Maybe it can help...
Posted: Friday 15 December 2017 19:44
by lcervo
I can see they have closed my ticket (https://github.com/OpenZWave/open-zwave/issues/1396) and added the new xml for the FGT-001:https://github.com/OpenZWave/open-zwave ... fgt001.xml.
Now... how can I use it? Do I need just to copy it in the domoticz folder of my rpi?
ta.
Posted: Saturday 16 December 2017 11:01
by marmo
bought one to test it and it is still on its way so I dont have in the system yet. But I had to go to the same process with my first Nodon some time ago as it was still not in the database. Assuming the process would be the same, we need to do copy the fgt001.xml file into/Config/fibaro.
then edit the manufacturer_specific.xml file to add something like this:
<Product type="1301" id="1000" name="FGT001 Heat Controller" config="fibaro/fgt001.xml"/>
include the node and it should be properly recognized.
Again, not tested with it yet, but likely similar action as when the Nodon first appeared in the market. let me know if it works pls, I'll need to do the same in the next days when mine arrives.
Posted: Saturday 16 December 2017 13:01
by fr3sh
It's still not recognized properly. I have added fgt001.xml and manufacture_specyfic.xml on the right places.
Posted: Saturday 16 December 2017 13:47
by fr3sh
Check my post I'v made it to start working :)
viewtopic.php?f=24&t=20851&p=161905#p161905
