Hello
I had a home made RFLINK, using RXB6 433,92 and XD-FST FS1000A: worked fine with multiple 433 Plugs, and an oregon weather station (Temp, Rain, Wind sensors), but I was not able to drive my Somfy RTS Blinds.
So I bought a RFLINK NODO board, including an Aurel Tranceiver 433.42 MHz (Somfy RTS) to replace it
Now Somfy blinds are working perfectly, I'm still able to drive 433 plugs, but I don't see any more my Oregon Weather Sensors!
Is there something to do to have everything working with 1 Hardware? Or shall I buy a second arduino and have 2 RFLINK plugged on my Domoticz?
Thanks for advices.
Rege
SOMFY RTS + 433,92 Devices?
pmarcus
- Domoticz version: 4.10256
Re: SOMFY RTS + 433,92 Devices?
Hello Regge,rege wrote:Hello
Thanks for advices.
Rege
i hope you have solved you problem. But i have an RF-link and i have not succeded in controlling my blinds. I know how to program the rflink but i cant get it to work with Domoticz.
Can you explain how you prepared domoticz to control the blinds?
thanks in advance
paul
TheCub3
Same Here Paul
I also dont see the Somfy
Also with a rf LINK
Also with a rf LINK
galinette
Somfy RTS is a rolling code remote protocol, so you can't "see" the blinds as you would see a sensor. You need to manually create the switch in the switches panel, using Blinds type, RFY protocol, set any code that is not used yet, put your blinds in "Learn" mode, and quickly send a command with the domoticz switch. The blind will learn the new (virtual) remote.
Better explained there : https://www.domoticz.com/wiki/RFXtrx433E , for the RFXtrx, but same procedure.
