I/m using Raspian Jessie on a raspberry pi 3
And i would integrate evohome
Bu i have a problem
The line echo 10ac 0102 > /sys/bus/usb-serial/drivers/ti_usb_3410_5052_1/new_id doesn't work for me
I also get an error:
-bash: /sys/bus/usb-serial/drivers/ti_usb_3410_5052_1/new_id: Permission denied
How can is solve this.
Now its not binding.
I'm new on Linux
I've copied the firmware ti_3410.fw in /lib/firmware
Thats the output with dmesg
[ 3.077511] usbcore: registered new interface driver ti_usb_3410_5052
[ 3.080075] usbserial: USB Serial support registered for TI USB 3410 1 port adapter
[ 3.085007] usbserial: USB Serial support registered for TI USB 5052 2 port adapter
Evohome integration
- philchillbill
Re: Evohome integration
Are you using 'sudo' before each command to give yourself root permissions to do everything?
- EdddieN
- Domoticz version: 4.9700
Do yo have the ti_3410 drivers installed?
I have a copy that I got from the internet...
11101101 - www.machinon.com
