User variable did not change by event
denman091
Domoticz version: 3.8153
Post by denman091 »
He,
i have one virtual switch for my smartphone and one for my wifes smartphone. if one of us is at home (connect with the wifi) the virtual switch turns on.
Now i want a variable that goes to "1" if one of the two virtual switches is on. and when both virtual switches are off (so we are not at home) the variable need to change to "0".
I made a user variable with type: Float and name "Thuis".
i made the following event: Image
image uploader
Why is this not working?
kuifje
Domoticz version: latest
Re: User variable did not change by event
Post by kuifje »
Does it work on a specific time table, for instance When its 10 am. So no triggers from a phone but a clock.
When that does work you can go on from here.
Good luck.
Kuifje
denman091
Post by denman091 »
kuifje wrote: Friday 08 December 2017 15:27 Does it work on a specific time table, for instance When its 10 am. So no triggers from a phone but a clock.
Good luck.
Kuifje
Now the event begins with IF: time > 00:00 and smartphone 1 or smarphone 2 = ON.
and now i receive the following error in the log:
2017-12-09 00:55:08.151 Error: EventSystem: Lua script error (Blockly), Name: Set Thuis variabel_2 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: ')' expected near 'comparevariable
StanHD
Post by StanHD »
I have similar events working with variables. I would use an Integer type Variablefor this.
May be worth a try?
Python:- Broadlink RM2, Sonos
denman091
Post by denman091 »
StanHD wrote: Saturday 09 December 2017 6:34 I have similar events working with variables. I would use an Integer type Variablefor this.
May be worth a try?
I changed it to integer and make the event with 1 switch and that works.
This works:
Then i change te event for 2 switches like:
And this works not. What is wrong with this event? it looks like domoticz don't understand the "OR" in de event.
Or domoticz can not handle two switches in one part.
I put one of the switches "ON" but see not happens in the log.
Edit post:-------------------------------------------------------------------------------------------------------------------------------------------------
Ok, i found the problem.
The event has be like this:
This is working.
denman091
Post by denman091 »
problem solved.
See edit post
wuschels
Domoticz version: stable
Post by wuschels »
It's much more easier to use "external input" in logical blocks.....
1x Pi1 (PiHole)
4x Pi3 ( Nextcloud, Domoticz, Kodi, MagicMirror)
1x AMD Quad-core, 32Gbyte RAM (SuSE-Linux, Vmware....)
