Vocal Command. Open jarvis local home assistant.
landaisbenj
Domoticz version: stable
Post by landaisbenj »
Hello.
I post you openjarvis with multiple plugin, and i do one for domoticz. It's my first so i seek idea to implement in.
DIY, local if you want, JSONAPI, french but most english.
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
EdwinK
Re: Vocal Command. Open jarvis local home assistant.
Post by EdwinK »
Now if I could only read French..
landaisbenj
Install is in english. And almost all plugin are translate, or easy to translate.
Video for install is just enough.
Or do:
sudo apt-get install -y git # install git if you don't have it already
git clone https://github.com/alexylem/jarvis.git
cd jarvis/
./jarvis.sh
Much of issue in github are translate.
Platforme: Rpbi3b
insippo
Post by insippo »
That is all ?
Sent from my SM-G950F using Tapatalk
landaisbenj
Yes for beginning. Install and configure. In case of error git hubs contributor can help in English
You can configure yourself with your own command.
And add some plugin for more function.
Platforme: Rpbi3b
insippo
Post by insippo »
I try today. I have speaker but i do not remember by mic.
landaisbenj
Easy with keyboard. But mic must be really good. Like jabra 410 or mic array for raspberry to have a quality like gh or other.
Platforme: Rpbi3b
insippo
Post by insippo »
Keyboard ? I connect over shh only to domiticz.
landaisbenj
Yes Jarvis work fine on ssh. Or with Jarvis ui plugin. Web interface
Platforme: Rpbi3b
insippo
Post by insippo »
I need learn how to and how it works and i need this or not. Domoticz only switch on and off my boilers today. Not more.
renerene
Post by renerene »
landaisbenj wrote: Saturday 02 December 2017 10:53 Easy with keyboard. But mic must be really good. Like jabra 410 or mic array for raspberry to have a quality like gh or other.
Can you tell me more? What did you use before? What was the improvement increase% with Jabra? Did u use Bluetooth or USB?
what about the Plantronics Calisto 620-M?
