Python Plugin: request from url
Noudje
Post by Noudje »
I like to get date from an url like www.domain.com?p1=a&p2=b&p3=b. Is that possible with Domoticz.Connection'? I already tried several options with https://github.com/domoticz/domoticz/bl ... es/HTTP.py as an example, but always got the message:
resolve: Host not found (authoritative)
What is the correct procedure to retrieve a response from an url like 'www.domain.com?p1=a&p2=b&p3=b'?
Raspberry Pi 2 with latest beta version
1x Aeon Labs USB Z-Stick S2
5x Fibaro Modules
Dnpwwo
Re: Python Plugin: request from url
Post by Dnpwwo »
@Noudje,
Have a look at https://github.com/domoticz/domoticz/bl ... es/HTTP.py. It does a get on "/" but you could change it to "?p1=a&p2=b&p3=b" at line 47 and set the base domain via the Hardware page.
febalci
Post by febalci »
For the:
self.httpConn = Domoticz.Connection(Name="HTTP Test", Transport="TCP/IP", Protocol="HTTP", Address=Parameters["Address"], Port=Parameters["Port"])
line, the address parameter should only be the domain name: www.domain.com
For the other lines:
            sendData = { 'Verb' : 'GET',
                         'URL'  : '/?p1=a&p2=b&p3=b', # or you may have to use '/inde.html?p1=a&p2=b&p3=b'
                         'Headers' : { 'Content-Type': 'text/xml; charset=utf-8', \
                                       'Connection': 'keep-alive', \
                                       'Accept': 'Content-Type: text/html; charset=UTF-8', \
                                       'Host': Parameters["Address"]+":"+Parameters["Port"], \
                                       'User-Agent':'Domoticz/1.0' }
Please note that HTTP usage in stable and latest beta is different. This will not work with the stable.
Noudje
Post by Noudje »
Thnx for the help!
Meanwhile I found another solution. Now I use urllib to retrieve a csv file from the url.
5x Fibaro Modules
Dnpwwo
Post by Dnpwwo »
@Noudje,
No problem. Just be aware that using urllib will stall the plugin framework while your plugin waits for a response because urllib is synchronous. That won't be a problem if you only run 1 or 2 plugins but can be if you run more than that.
The built in connection solution is asynchronous so will scale much better.
Users browsing this forum: willemd and 1 guest
