Check ESP-01/12 Online Status
sisaenkov
Domoticz version: 3.8
Re: Check ESP-01/12 Online Status
Post by sisaenkov »
Crash123 wrote: Thursday 23 November 2017 7:11 Hello,
sometimes my ESP´s get lost. I do not sure whether the ESP lost the wifi connection or my wifi modem lost the esp´s.
So how could I check whether they are online or not? If they get lost, domoticz should push my a pushbullet message. Pushbullet is already working on my system.
Thanking you in Advance for your support!
1. Do you call ESP by hostname or IP-address?
2. In my case if I restart router without restarting Wi-Fi AP (UniFi), then the router lost ESP hostname and IP-address (given by DHCP) matching, and I can't reach it by hostname. Fixed it by setting static record for ESP hostname. I check my ESP in Zabbix. You can check it by cron with bash-sctipt like this:
#!/bin/bash
ping -c2 172.16.1.101
if [[ $? -eq 0 ]]; then
	DO SOMETHING via Domoticz API;
fi
sisaenkov
Post by sisaenkov »
You can change ping checking by curl:
curl -m 2 -iks http://192.168.5.15:80 | grep '200 OK'
woody4165
Post by woody4165 »
In this case you will have Ping device changed by the last value of the last IP address.
You should create one device for each IP address you are going to ping and then use
commandArray['Ping_x']=state
where x is a progressive number.
Or just use for each device a name that identifies the pinged address.
inzuno
Domoticz version: stable
Post by inzuno »
If you use ESPeasy , there's an easy way to report ip and many status to domoticz check here:
https://www.letscontrolit.com/wiki/inde ... rial_Rules
https://www.letscontrolit.com/wiki/inde ... using_MQTT
And I used the Domoticz Json URLS: https://www.domoticz.com/wiki/Domoticz_ ... _variables
Personnaly I made this rules:
On System#Boot do    //When the ESP boots, do
  SendToHTTP DomoticzIPorHostnameHere,8080,/json.htm?type=command&param=updateuservariable&vname=YourUserVariableHere&vtype=2&vvalue=%ip%
  SendToHTTP DomoticzIPorHostnameHere,8080,/json.htm?type=command&param=udevice&idx=123456789&nvalue=0&svalue=%ip%
timerSet,1,3600      //Set Timer 1 for the next event in x seconds
endon
On Rules#Timer=1 do  //When Timer1 expires, do
  timerSet,1,3600       //Resets the Timer 1 for another x seconds
endon
You need to create a user variable in domoticz with string parameter or/and a text dummy.
Don't forget to change this values in the code, as well as Domoticz IP or hostname and port.
You need to be careful with this rules because when you update it in the ESP there's a bug with the "&param" becoming "¶m" so every time you change something in this rules you need to update this.
-------------------edit------------------
workaround for the &param issue:
  SendToHTTP DomoticzIPorHostnameHere,8080,/json.htm?param=updateuservariable&type=command&vname=YourUserVariableHere&vtype=2&vvalue=%ip%
  SendToHTTP DomoticzIPorHostnameHere,8080,/json.htm?param=udevice&type=command&idx=123456789&nvalue=0&svalue=%ip%
endon
endon
"I never make the same mistake twice. I make it like five or six times, you know, just to be sure."
kimot
Domoticz version: v3.8153
Post by kimot »
I suppose your ESPeasy sends periodically some data to Domoticz.
If this data are not coming for certain time, Domoticz can send message to you.
Use .lastUpdate attribute.
Example script here:
https://github.com/dannybloe/dzVents/bl ... evices.lua
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
