Support for Steinel
Posted: Tuesday 21 November 2017 22:15
by Ivanhoe1
Does domoticz have support for Steinels new z-wave products? Like the Xled: http://www.steinel.de/en/smart-home/sma ... -wave.html
Re: Support for Steinel
Posted: Friday 01 December 2017 13:46
by dolusystem
Hello I will be very interested to get the configuration xml file for Steinel devices which are very nice.
I found that file but too complex to handle for me
http://contenido.steinel.de/brand/uploa ... 5_2017.pdf
Posted: Sunday 10 December 2017 8:29
by sailmich
Hello here is the xml file. I use the file for xledh2 and is140-2. PIR / switch and Lux is working. When you don't want to change settings of the devices no need to have the xml. They working out of the Box.
xledh2.xml
(9.6 KiB) Downloaded 275 times
Posted: Tuesday 12 December 2017 11:50
by sailmich
sailmich wrote: Sunday 10 December 2017 8:29 Hello here is the xml file. I use the file for xledh2 and is140-2. PIR / switch and Lux is working. When you don't want to change settings of the devices no need to have the xml. They working out of the Box.
xledh2.xml
edit: After a while they lost connection and stop to report. I have that mostly with just one out of three devices. I will check if it is a problem of distance.
Posted: Friday 12 January 2018 23:14
by GammaKappa
I am running Domoticz V3.8153 on a RasPi 3 with an Aeotec GEN5 stick controller.
I managed to get the z-wave part up and running with a Fibaro Wall Plug, a NeoCool PIR sensor and a Qubino relay, all working fine.
I added a Steinel XLED home 2 Z-wave using the xledh2.xml from sailmich. Switching and parameter setting is working.
However after a number of on/off switching of the lamp, the system seems to go crazy and get in an endless communication loop between the controller and the Steinel.
When I monitor the 868 Mhz channel with sdr# I can see it is flooded by continuous rf transmissions that only stops when I cut the power from the Steinel.
The OZW_log file is mostly filled with lines like :
2018-01-12 14:06:34.491 Info, Node008, Received Basic set from node 8: level=0. Sending event notification.
2018-01-12 14:06:34.491 Detail, Node008, Notification: NodeEvent
2018-01-12 14:06:34.516 Detail, Node008, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x08, 0x03, 0x20, 0x01, 0x00, 0xd8
2018-01-12 14:06:34.516 Info, Node008, Received Basic set from node 8: level=0. Sending event notification.
2018-01-12 14:06:34.516 Detail, Node008, Notification: NodeEvent
2018-01-12 14:06:34.541 Detail, Node008, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x08, 0x03, 0x20, 0x01, 0x00, 0xd8
at a rate of one per 25 msec !
Can anybody point me in a direction to find a solution ?
