Support for Steinel
Ivanhoe1
Support for Steinel
Does domoticz have support for Steinels new z-wave products? Like the Xled: http://www.steinel.de/en/smart-home/sma ... -wave.html
dolusystem
- Domoticz version: 2.3530
Re: Support for Steinel
Hello I will be very interested to get the configuration xml file for Steinel devices which are very nice.
I found that file but too complex to handle for me
http://contenido.steinel.de/brand/uploa ... 5_2017.pdf
sailmich
Hello here is the xml file. I use the file for xledh2 and is140-2. PIR / switch and Lux is working. When you don't want to change settings of the devices no need to have the xml. They working out of the Box.
sailmich
edit: After a while they lost connection and stop to report. I have that mostly with just one out of three devices. I will check if it is a problem of distance.sailmich wrote: Sunday 10 December 2017 8:29 Hello here is the xml file. I use the file for xledh2 and is140-2. PIR / switch and Lux is working. When you don't want to change settings of the devices no need to have the xml. They working out of the Box.
GammaKappa
- Domoticz version: 2023.2
I am running Domoticz V3.8153 on a RasPi 3 with an Aeotec GEN5 stick controller.
I managed to get the z-wave part up and running with a Fibaro Wall Plug, a NeoCool PIR sensor and a Qubino relay, all working fine.
I added a Steinel XLED home 2 Z-wave using the xledh2.xml from sailmich. Switching and parameter setting is working.
However after a number of on/off switching of the lamp, the system seems to go crazy and get in an endless communication loop between the controller and the Steinel.
When I monitor the 868 Mhz channel with sdr# I can see it is flooded by continuous rf transmissions that only stops when I cut the power from the Steinel.
The OZW_log file is mostly filled with lines like :
2018-01-12 14:06:34.491 Info, Node008, Received Basic set from node 8: level=0. Sending event notification.
2018-01-12 14:06:34.491 Detail, Node008, Notification: NodeEvent
2018-01-12 14:06:34.516 Detail, Node008, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x08, 0x03, 0x20, 0x01, 0x00, 0xd8
2018-01-12 14:06:34.516 Info, Node008, Received Basic set from node 8: level=0. Sending event notification.
2018-01-12 14:06:34.516 Detail, Node008, Notification: NodeEvent
2018-01-12 14:06:34.541 Detail, Node008, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x08, 0x03, 0x20, 0x01, 0x00, 0xd8
at a rate of one per 25 msec !
Can anybody point me in a direction to find a solution ?
