Where are LUA and Python scripts from script editor stored?
Jumper3126
I really like the new script editor in Domoticz, and recently moved all my LUA and DzVents scripts into it. I also want to move my python scripts, but I need to know where there are finally stored so I know what adress to call from for example crontab.
mischa
- Domoticz version: 3.8872
Re: Where are LUA and Python scripts from script editor stored?
On a PI the LUA scripts are stored in the /home/pi/domoticz/scripts folder or if you are using DZVents (see settings => other page (checkbox unchecked)) in the /home/pi/domoticz/scripts/dzvents/scripts folder.
If you use domoticz on a synology nas it will be /volume1/@appstore/domoticz/var/scripts and for DZVents /volume1/@appstore/domoticz/var/scripts/dzvents/scripts.
I think the Python scripts are stored in the scripts folder not the dzvents script folder.
Pi 2 - Pi 1 - Razzbery 2.0 - Fibaro FGD-211 - Fibaro FGD-212 - Fibaro FGRGBWM-441 (RGBW Module) - Fibaro FGBS321 (Universal Switch) - FGWPF-102 - TBK Home TZ67-G - Synology DS1515+ - Esp Easy (with wemos D1 mini)
dannybloe
The dzVents scripts you write using the GUI editor are stored in scripts/dzVents/generated_scripts.
