I have a selector switch of my thermostat, i made a auto program switch containing No, Yes and Temporary.
This is based on the thermostat setpoint. So when the thermostat is following the program it is set to Yes and if i adjust the temp outside the program the selector goes to temporary. Now i want this temporary switch go back to Yes after 30 minutes so i created a new lua.
-- Command Selector Switch
if (otherdevices['Toon Auto Program'] == 'Set Level: 30')then
commandArray['Toon Auto Program']='Set Level: 20 AFTER 10' -- seconds
print('Toon loopt weer via het programma')
commandArray['SendNotification']='Toon loopt weer via het programma'
