Dashticz - Function - Playsound/Speak
DewGew
Domoticz version: V4.10618
Simple text to speak via browser
Post by DewGew »
This is a simple text to speak using Speech Synthesis API to make your browser speak. I had to use the variables onCalled and offCalled for the speak to run once else it starts over again and again and....maybe someone have simpler way to do this.
Put this codes in custom.js:
Speech function:
// Speech function
function speak(textToSpeak) {
   var newUtterance = new SpeechSynthesisUtterance();
   newUtterance.text = textToSpeak;
   newUtterance.lang = 'en-GB'; // change to your langage if its supported (nl-NL, en-GB, de-DE, etc)
   window.speechSynthesis.speak(newUtterance);
Device:
// Devices that run speak function
// change 136 to your idx
var onCalled_136 = false
var offCalled_136 = false
function getStatus_136(idx,value,device){
	if(device['Data']=='On'){
		if(!onCalled_136){
			speak('Device is on');
			onCalled_136 = true
	else{
		if(!offCalled_136){
			speak('Device is off');
			offCalled_136 = true
DewGew
Post by DewGew »
New functions for playsound and speak is added in latest Beta.
Speak works only in english female voice at the moment.
How to use:
blocks[123]['playsoundOn'] = 'sounds/airplane.mp3'; //only when turn on
blocks[123]['playsoundOff'] = 'sounds/ping.mp3'; //only when turn off
blocks[123]['speakOn'] = 'Device is on';
blocks[123]['speakOff'] = 'Device is off';
blocks[123]['playsound'] = 'sounds/button_click.mp3' //toggle
blocks[123]['speak'] = 'Device has toggled';
DewGew
Re: Simple text to speak via browser
Post by DewGew »
This fuction is now added to latest beta read at this topic:
viewtopic.php?f=67&t=20426
robgeerts
Domoticz version: 3.7067
Re: Dashticz - Function - playsound/speak
Post by robgeerts »
Works great, in addition:
Remove 'speak' and 'playsound' when you are also using 'speakOn'/'speakOff' and 'playsoundOn'/'playsoundOff'
gielie
Domoticz version: latest β
Re: Dashticz - Function - Playsound/Speak
Post by gielie »
Nice work only i can't get the sound to work on my iPad, on my mac it works great tho.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
Vomera
Post by Vomera »
I’m using dashticz on my android tablet (Samsung tab a).
When I open dashticz on the Samsung browser I can get sounds when I change a button. Device is turned on or off. But when I use fully kiosk browser it doesn’t work. Is this a bug in dashticz or the fully kiosk browser? How can I solve the problem?
edit: speak function doesnt work, mp3 sounds works
mAiden88
Domoticz version: 3.7286
Post by mAiden88 »
I got little bit the same issue.. On my desktop it works perfect, on my ipad i dont get any sound or speak.
Anyone can build a fast processor. The trick is to build a fast system.
Vomera
Post by Vomera »
mAiden88 wrote: Thursday 10 May 2018 14:07 I got little bit the same issue.. On my desktop it works perfect, on my ipad i dont get any sound or speak.
Also on other browsers ?
mAiden88
Post by mAiden88 »
Vomera wrote: Friday 11 May 2018 13:11
I try:
Safari
Chrome
Firefox
On My Windows desktop i use Chrome.
Vomera
Post by Vomera »
At the moment i use only the mp3 options, as workaround that works for me.
I tried it on my iphone on safari, it works.
Is your sound turned on ?
Volume up to 100%?
Do not disturb off ?
What ios version do you have ?
mAiden88
Post by mAiden88 »
Vomera wrote: Friday 11 May 2018 13:31 At the moment i use only the mp3 options, as workaround that works for me.
Volume up to 100%?
Let me introduce myself first .. I am certificated in ICT.
Now follow an education to application developer
Yes my sound are on and on 100%.
Do not disturb off is not set.
I have iOS version 11.3
Vomera
Post by Vomera »
Tnx for the introduction so then you know what you are doing :)
Correction i tried it again on iphone and ipad and it doesnt work anymore :/ strange.
when i switch a button with sound on my iphone the samsung tablet works fine but iphone will not respond.
(i have a samsung tablet on my wall)
gielie
Post by gielie »
It is a iOs problem i think, Rob doesnt have a iOs device so he cant test it.
- FIBARO FGS223
- Toon
- Kodi Media Server
zodracom
Domoticz version: V4.7900
Post by zodracom »
Vomera wrote: Thursday 10 May 2018 13:24 Hi,
someone has the solution allready? have the same problem :-(
robgeerts
Post by robgeerts »
zodracom wrote: Wednesday 06 March 2019 17:49
Its a known problem with Kiosk for a long time..
Cant you use chrome for this? (I thought only benefit was fullscreen mode but its possible inside Dashticz now? Or am i missing something?)
Vomera
Post by Vomera »
robgeerts wrote: Monday 11 March 2019 22:32
I will check this when i'm home. Didnt know there is a full screen mode in dashticz now! I miss that part!
madpatrick
Domoticz version: 2025.1
Post by madpatrick »
When ik try to add the script to custom.js, it is not working in my tablet with Fully Remote
On my pc i can hear the message playing.
On the tablet I see the following error
Error : SpeechsynthesisUtterance is not deficed  Check function getStatus_262 in custom.js line 2206:22
This is the part of custom.js for block 262
function getStatus_262(block) {
    var Data = block.device.Data;
    var idx = block.idx;
    var device = block.device;
    if (parseFloat(Data) < 1.5) {
        trigger_262 = true;
        block.addClass = 'warning';		// set the addClass parameter for block 262
	speak('Alarm is is  triggered');
    else {
        trigger_262 = false;
        block.addClass = ''; // reset the addClass parameter for block 262
    handleRegen();
-= HP server GEN11 =- OZW -=- Toon2 (rooted) -=- Domoticz v2025.1 -=- Dashticz v3.14b on Tab8" =-
Users browsing this forum: jberinga and 1 guest
