get last JSON values
devros
Post by devros »
hi all,
im playing with ESP32(with battery and oled) & Micropython that will display (and refresh) some actual data from domoticz. Works good so far. I can display energy saved today extracted from JSON.
I would like to get actual power from json, but i can use only day range a json file is quite huge for my ESP memory
/json.htm?type=graph&sensor=counter&idx=IDX&range=day
I want last value in json file anyway :).
Any idea how to get only last entry in JSON from domoticz (something like &range=actual) where will be only last entry....
Could be possible to make some dirty python script, but would be great to get that directly from domoticz.
Any idea, how to solve this ?
htilburgs
Re: get last JSON values
Post by htilburgs »
devros wrote: Wednesday 15 November 2017 14:37 hi all,
Can this work? Where rid is the IDX of the device.
json.htm?type=devices&rid=4
In the results you get "Data: " with the last result, see my example for the RPi Temperature.
This you can extract and you get your last result.
"ActTime" : 1510755671,
   "ServerTime" : "2017-11-15 15:21:11",
   "Sunrise" : "07:57",
   "Sunset" : "16:48",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "35.8 C",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 3,
         "HardwareName" : "Moederbord Sensoren",
         "HardwareType" : "Motherboard sensors",
         "HardwareTypeVal" : 23,
         "HaveTimeout" : false,
         "ID" : "0001",
         "LastUpdate" : "2017-11-15 15:20:12",
         "Name" : "Raspberry PI Temperatuur",
         "Notifications" : "false",
         "PlanID" : "2",
         "PlanIDs" : [ 2, 2 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "LaCrosse TX3",
         "Temp" : 35.799999999999997,
         "Timers" : "false",
         "Type" : "Temp",
         "TypeImg" : "temperature",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "4"
   "status" : "OK",
   "title" : "Devices"
Hardware:
SweetPants
Post by SweetPants »
If you use MQTT and subscribe to topic domoticz/out, every time domoticz receives the last power value, it is published on this topic too in a JSON like:
"Battery" : 255,
"RSSI" : 12,
"description" : "idx: 60\nESP_022A24",
"dtype" : "General",
"id" : "00082059",
"idx" : 60,
"meterType" : "Energy",
"name" : "CV_Pomp Energie",
"nvalue" : 0,
"stype" : "kWh",
"svalue1" : "3.500",
"svalue2" : "21967.500",
"unit" : 1
devros
Post by devros »
htilburgs wrote: Wednesday 15 November 2017 15:24
Yay, I was blind, how can i miss this :)
thanks a lot
devros
Post by devros »
SweetPants wrote: Wednesday 15 November 2017 15:35 If you use MQTT and subscribe to topic domoticz/out, every time domoticz receives the last power value, it is published on this topic too in a JSON like:
"Battery" : 255,
"RSSI" : 12,
"id" : "00082059",
"idx" : 60,
"nvalue" : 0,
"stype" : "kWh",
"unit" : 1
Thanks but for this i need MQTT client, dunno if this can ESP32 can handle, want to keep my code simple anyway
