RFLink Somfy : put a blind in learn mode
rege
Post by rege »
Hello
I have a domoticz with RFLink from nodo shop working with my Somfy blinds.
One of them has lost his origin remote pairing , but is still paired with RFLink
Is there a command from RFLink to put it in learn mode in order to pair with the original remote?
nigels0
Domoticz version: 3.8153
Re: RFLink Somfy : put a blind in learn mode
Post by nigels0 »
As I recall, on my ones, I needed to manually reset and put the blind in learn mode; there is a small button that you press in with a paperclip on each blind. You may have different ones.
Instructions here:
http://www.expertshutters.com/SomfyST50 ... etting.pdf
rege
Post by rege »
Thanks a lot.
I was looking for a software solution, but this works fine also.
