Geo Coordinates Topic is solved
bluepi
Geo Coordinates
Post by bluepi »
Hello all,
After a bit of help..
I have been playing with pyicloud after being impressed with the geofencing in Home Assistant.
So I have cobbled together (borrowed huge amounts of other code) a python script that logs my coordinates every 5 mins and turns on a couple of switchs if my phone is in one of two geofences (Home and Work).. This is all working with 2 factor.
this is running per person in the house hold but I am stuck on a couple of sections..
I turn on a switch (home and work) - this works fine
I am dumping all the other data I get back from icloud into a text sensor. This is not the best way to deal with this.. Where else can I stick this data so I get a nice format of long Lat that I can then take into node red and plot on a map. I also want to log this data so I can use it for other functions (predictive coming home etc)
How can I map each persons location on the same map (going to look at the sample from Owntracks and follow this)
Soon as I have cleaned the code up and got these last two bits done I plan on releasing this mess of a code in the hope that someone can write a nicer version for Domoticz for me to use :-)
