Reading thermostat value in lua
Thomasdc
Post by Thomasdc »
Hi!
I'm trying to configure my heating system to switch on and off with a certain hysteresis..
but i can't find out how that i need to read out the virtual thermostat value
i've tried so much allready..
this is the code at this moment:
local Temperature = 'Temperatuur living'
local Temperature_SP = 'Thermostaat'
local Heating = 'KachelSP'
local AutoMode = 'HeatingAuto'
local Calc_Temperature = otherdevices[string.format('%s_Temperature', Temperature)]
local Calc_Temperature_SP = otherdevices[string.format('%s_Temperature', Temperature_SP)]
local Temp_Hys = 'TemperatuurHys'
Calc_TempHys = tonumber(uservariables[Temp_Hys])
Calc_Temperature = tonumber(Calc_Temperature)
Calc_Temperature_SP = tonumber(Calc_Temperature)
if otherdevices[AutoMode] == 'On' then
  if ( Calc_Temperature > (Calc_Temperature_SP + Calc_TempHys) ) then
     commandArray[Heating] = 'On'
     print('Auto Mode  Heating , Turned on Stove ')
    elseif ( Calc_Temperature < ( Calc_Temperature_SP - Calc_TempHys)) then
     commandArray[Heating] = 'Off'
     print('Auto Mode  Heating , Turned Off Stove ')
can someone explain how this works:
otherdevices[string.format('%s_Temperature', Temperature_SP)] ?
it's something i found on an example but i dont really understand what it does..
any help is welcome!
freijn
Domoticz version: Stable
Re: Reading thermostat value in lua
Post by freijn »
is
also the name of your theromostat?
Thomasdc
Post by Thomasdc »
freijn wrote: Thursday 09 November 2017 14:46 is
'Temperatuur living' --> temperature sensor
'Thermostaat' --> the virtual thermostat
freijn
Post by freijn »
ok
put a
print (otherdevices[string.format('%s_Temperature', Temperature_SP)])
and see what appears in the log file?
What are you seeing?
Thomasdc
Post by Thomasdc »
the only thing i see in the log file is this
2017-11-09 18:45:00.316 Error: EventSystem: in KachelSp: [string " ..."]:21: attempt to perform arithmetic on local 'Calc_Temperature_SP' (a nil value)
the ' print (otherdevices[string.format('%s_Temperature', Temperature_SP)]) ' doesnt appear in the log,
(i did put it just under the line ' commandArray = {} '
freijn
Post by freijn »
Can you move up the
So it becomes :
and try again ?
Thomasdc
Post by Thomasdc »
same error:
2017-11-10 18:24:00.308 Error: EventSystem: in KachelSp: [string " ..."]:23: attempt to perform arithmetic on local 'Calc_Temperature_SP' (a nil value)
Thomasdc
Post by Thomasdc »
Someone who can help me figure it out?
or someone who can share his script with me?
i'm sure there are a lot of you who uses a temperature sensor, virtual thermostat and a hysteresis to control the heating?
my biggest problem are:
How to read out the virtual thermostat (setpoint) and the temperature sensor.. (but i think that may allready work, the code only gives error on the thermostat value)
Thomasdc
Post by Thomasdc »
for anyone wondering what i was doing wrong..
this is working:
local iThermostatSetPoint = tonumber( otherdevices_svalues[Temperature_SP] )
local iTemperature = tonumber( otherdevices_svalues[Temperature])
   print('testing value'..iThermostatSetPoint)
  if ( iTemperature > (iThermostatSetPoint + Calc_TempHys) ) then
     print('Auto Mode  Heating , Turned off Stove ')
    elseif ( iTemperature < (iThermostatSetPoint - Calc_TempHys)) then
     print('Auto Mode  Heating , Turned On Stove ')
