Script to Check the state of your ADSL box from your Domoticz & reboot if needed
Posted: Tuesday 07 November 2017 22:22
by TiXav
The script is for SFR box (France) but I think it could be adapted for your own operator
It get the status of your adsl and reboot the box if needed
It get the Adsl mode Download Upload Speed
I hope, this could help someone :D
First I just install (if not yest installed)
apt-get -y install php7.0-curl
apt-get -y install php7.0-xml
I created 2 devices in domoticz
1) a dummy text
Adsl Status.PNG (10.26 KiB) Viewed 1663 times
Adsl values setup selector.PNG (37.44 KiB) Viewed 1663 times
2) a dummy selector switch
Adsl values.PNG (6.55 KiB) Viewed 1663 times
The code to copy into a file in your script folder
In the comment of the file, I wrote a way to start it from LUA but can be done by an another way such as cron...
<?php
 /* list of all SFR BOX API
 http://efixo-dev.pfd.sfr.net/doc/api-rest.html
					Box Const to setup
//box API method
$apiUrl = "http://192.168.1.1/api/1.0/?method=";
//username to connect to the box
$user = "admin";
//password to connect to the box
$password = "";
					Install the file
	copy the file into /home/domoticz/scripts/
	make the script executable chmod 755 yourfile.php
					Setup to do in domoticz
	create a dummy Selector switch
		set 10 level Unconnected (or with your own language)
		set 20 level Connected
		set 30 level Reboot
	create a dummy Text
in device event
	--to update the dummy text to know whate is the speed of the adsl after a new connected state
	if ( devicechanged['SfrBox'] == 'Connectée' ) then
		os.execute ("php -f /home/domoticz/scripts/yourfile.php -- --action monitor")
in time event
	--to check every 5 minutes the state of ADSL
	-- we send the current state to the php file because
	-- 			if the --oldstate was unconnected then php reboot the box
	--			to update the selector switch only if there is a change
	-- REPLACE SfrBox BELOW by the name of your selector switch
	time = os.date("*t")
	StrMinutes=tostring(time.min):sub(-1)
	if StrMinutes=="5" or StrMinutes=="0" then
		os.execute ("php -f /home/domoticz/scripts/yourfile.php -- --action check --oldstate "..otherdevices['SfrBox'])
					Selector switch in domoticz
//level 10 for Unconnected : Same as defined in domoticz
$ConstUnconnected="Déconnectée";
//level 20 for Connected : Same as defined in domoticz
$ConstConnected="Connectée";
//selector index
$SelectorSwitchIndex="415";
					Dummy text in domoticz (to receive ADSLMODE DOWNLOAD UPLOAD)
$TextIndex="505";
$usage = 'php -f ' . basename(__FILE__) . " -- \\\n\t"
	. "[ -a | --action check|monitor|reboot] \\\n\t"
	. "[ -o | --oldstate ] \\\n\t";
$longopts  = array(
	'action:',
	'oldstate:',
$options = getopt('a:o:', $longopts);
//var_dump($options);
// Process action argument
if (!isset($options['action']) && !isset($options['a'])) {
	die("Missing --action argument.\nUsage:\t$usage\n");
$action = isset($options['action']) ? $options['action'] : $options['a'];
// Process oldstate argument
if (isset($options['oldstate'])) {
	$oldstate = $options['oldstate'];
elseif (isset($options['o'])) {
	$oldstate = $options['o'];
// check oldstate present if action is 'check'
if ($action=="check" && !isset($oldstate)) {
	die("Missing 'oldstate' argument, ie: --action check --oldstate|-o $ConstUnconnected|$ConstConnected .\nUsage:\t$usage\n");
function testWan(){
		$socket = @fsockopen("www.google.com", 80);
		if ($socket === false) {
			return 0;
		} else {
			return 1;
function PrivateRequest($request) {
		$authToken=authhh();
		$URL = $GLOBALS['apiUrl'].$request."&token=".$authToken;
		$ch = curl_init();
		print_r($URL);
		curl_setopt($ch, CURLOPT_URL, $URL);
		curl_setopt($ch, CURLOPT_POST, true);
		curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
		curl_setopt($ch, CURLOPT_POSTFIELDS, "dummy");
		$response = curl_exec($ch);
		curl_close($ch);
		print_r($response);
function domoticzCommand($idx,$cmd,$choix) {
		$domoticzurl='http://127.0.0.1:8080/json.htm?';
		$chain="";
		switch ($choix) {
			case "switch":
				$chain=$domoticzurl.'type=command&param=switchlight&idx='.$idx.'&switchcmd='.$cmd;
				break;
			case "Custom Sensor":
				$chain=$domoticzurl.'type=command&param=udevice&idx='.$idx.'&svalue='.$cmd;
				break;
			case "Text":
				break;
			case "Message":
				$chain=$domoticzurl.'type=command&param=addlogmessage&message='.$cmd;
				break;
			case "SelectorSwitch":
				$chain=$domoticzurl.'type=command&param=switchlight&idx='.$idx.'&switchcmd=Set%20Level&level='.$cmd;
				break;
		$reply=json_decode(file_get_contents($chain),true);
		if($reply['status']=='OK') $reply='OK';else $reply='ERROR';
		echo($reply);
		return $reply;
function authhh(){
		//get token from the box
		$tokenXML = simplexml_load_file( $GLOBALS['apiUrl'] . "auth.getToken" );
		$token = $tokenXML->auth[0]->attributes()->token;
		//hash the username with the token
		$hmacUser = hash_hmac('sha256', hash('sha256', $GLOBALS['user'] ), $token);
		//hash the passwd with the token
		$hmacPassword = hash_hmac('sha256', hash('sha256', $GLOBALS['password'] ), $token);
		//concat the hashes
		$hash = $hmacUser . $hmacPassword;
		//get the auth Token
		$authXML = simplexml_load_file( $GLOBALS['apiUrl'] ."auth.checkToken&token=" . $token . "&hash=" . $hash );
		if( $authXML->attributes()->stat == "ok" ) {
			return $authXML->auth->attributes()->token;
		else {
			domoticzCommand("0","erreur de la fonction authhh",'Message');
			exit('erreur de la fonction authhh');
switch($action) {
	case 'check':
		$val=testWan();
		if ($val==1) {
			if ($GLOBALS['oldstate']!=$GLOBALS['ConstConnected']) {
				//adsl up update Dz
				domoticzCommand($SelectorSwitchIndex,"10",'SelectorSwitch');
			else{
				//domoticzCommand("0","SfrBox_check:Nochange",'Message');
		else {
			if ($GLOBALS['oldstate']!=$GLOBALS['ConstUnconnected']) {
				//adsl down update Dz
				domoticzCommand($SelectorSwitchIndex,"20",'SelectorSwitch');
			else{
				//if box was already down last time then reboot the box
				domoticzCommand($SelectorSwitchIndex,"30",'SelectorSwitch');
				PrivateRequest('system.reboot');
		break;
	case 'monitor':
		$MyXML = simplexml_load_file( $GLOBALS['apiUrl']."dsl.getInfo" );
		$str = $MyXML->dsl->attributes()->linemode;
		$str=str_replace('+',"plus",$str)."%20";
		$str .= $MyXML->dsl->attributes()->rate_down."%20";
		$str .= $MyXML->dsl->attributes()->rate_up."%20";
		domoticzCommand($TextIndex,$str,"Text");
		break;
	case 'reboot':
		break;
	default:
		die("Unknown --action argument.\nUsage:\t$usage\n");
