Hi Guys,
Is it possible to log my data readings (temperature and humidity) from Domoticz running on Raspberry Pi into internal folder or to LAN attached NAS storage (no external service). I need just hourly log with time stamp in some kind of text file.I have been searching on forum with no success.
Thanks a lot for suggestions.
Data Logging
- michaldobrotka
Data Logging
Domoticz on Raspi 3 and slave on ZeroW (running only with Broadlink plugin), Serial Mysensors GW on Arduino nano, Broadlink RM2, Rehau CO2 USB Stick, RF link 433 MHz, 2x Amazon Echo Dot (Controlicz), ESP2866 witk Espeasy, Sonoff
- emme
- Domoticz version: latest
Re: Data Logging
what about a script that write a file?
somthing like:
somthing like:
timer = {
'every minutes'
local devName = domoticz.devices('myTempHumidDeviceName')
local fileName = '/path/to/folder/filename.csv'
local timeStamp = os.date('*t')
fileOut = io.open(fileName, 'a')
fileOut:write(timeStamp..','..devName.temparature..','..devName.humidity..'\n')
fileOut:close()
}The most dangerous phrase in any language is:
"We always done this way"
- michaldobrotka
Re: Data Logging
Thanks emme, I will try it.
- michaldobrotka
Re: Data Logging
Hi emme,
Checked dzVents and changed your script to :
.csv file was created, but no logs were written after hour.
Am I missing something in script?
timer = {
'every hour'
local devName = domoticz.devices('Terrarium ground')
local fileName = '/home/domoticz/scripts/Datalogger/Terarriumgroundtemp.csv'
fileOut:close()
}Am I missing something in script?
- mack
- Domoticz version: Stable
Re: Data Logging
I didn't check your script logic, but wanted to point out for dzVents to be enabled, the checkbox for dzVents needs to be UNchecked.
Users browsing this forum: Amazon [Bot] and 1 guest
