FIBARO System FGMS001-ZW5 Motion Sensor
kryptonneke
Post by kryptonneke »
I have Fibaro motion sensor. And when I added the hardware to domotics a number of devices were created:
Currently I use the first one, the motion one.
Question is , when do I use the other ones? What is the General for? The Alarm Level & Type. And when to use the Event???
Benneton
Re: FIBARO System FGMS001-ZW5 Motion Sensor
Post by Benneton »
Did you work that out? I have added this same sensor today and have same devices.
Motion works in script, but I cannot get the dusk sensor to work, it only is on when motion is active, which I do not want, just want it as dusk sensor to switch lights on when dark.
Also I so not see what the Alarm level, Alarm Type, Burglar (could it be temper alarm?) and Alarm Type: Buglar 7 are used for?
Support much appreciated
