how to get rit of intruders
Posted: Saturday 28 October 2017 12:17
by BartSr
Hi.
My Domoticz is running on Raspberry Pi 3.
I have for internet access login name and password.
Now in the logfile I regular find :
Incoming connection from: 139.162.79.87 [ but also from other IP's].
How can I 'keep the system closed'? Is this dangerous?
KR
-Bart
Re: how to get rit of intruders
Posted: Saturday 28 October 2017 12:57
by woody4165
Do not open domoticz port to internet and install a VPN to access to it.
Or check the domoticz wiki, there should be some articles regarding security.
Posted: Saturday 28 October 2017 13:04
by jvdz
I am using Nginx as reverse proxy with a SSL connection and use Fail2Ban to monitor the Nginx logs and ban any connection after 2 failed tries. This way you run pretty secure.
You could also use the buildin SSL option, but never use the clear-text connection over port 8080 over the internet.
Jos
Posted: Saturday 28 October 2017 17:42
by Egregius
Fail2ban is the best option, I use it on my web server and on Domoticz.
And as Jos said, use ssl.
Posted: Saturday 28 October 2017 19:15
by lost
BartSr wrote: Saturday 28 October 2017 12:17
This kind of message is just a connection attempt, no login or even trying to do so.
You can't stop, for instance, web site indexing robots from trying to figure-out is there is something to index!
To avoid bruteforcers, fail2ban is a good option combined with a firewall to auto-buld temp rules to ban them.
Posted: Thursday 01 February 2018 8:25
by Damoms
Are you sure that domoticz isn't already running?
royal1688
Posted: Wednesday 07 February 2018 6:32
by tontze
Egregius wrote: Saturday 28 October 2017 17:42
Can you post your fail2ban config on domoticz part ? What you have in filter file etc ?
Posted: Wednesday 07 February 2018 18:41
by jvdz
This is the fail2ban (jail.local) config I use in combination with an nginx proxy setup:
You have to update in the
red marked items to your purpose:
- Spoiler: show
- # Check HTTPS Authentication for invalid username/Password
# 2 failures in 10 minutes hours -> ban 10 minutes
[nginx-auth-10min]
enabled = true
filter = nginx-auth
action = iptables-multiport[name=NoAuthFailures, port="http,https,??port used by domoticz on the public side??"]
telegram10min
logpath = /var/log/nginx/domoticz.error.log
maxretry = 2
bantime = 600
findtime = 600
# 5 failures in 24 hours -> ban 7 days
[nginx-auth-week]
enabled = true
filter = nginx-auth
telegram1week
maxretry = 7
bantime = 604800
findtime = 86400
# Check tries HTTP over HTTPS ports and simply block after 2 tries
[nginx-login-10min]
enabled = true
filter = nginx-login
action = iptables-multiport[name=NoLoginFailures, port="http,https,??port used by domoticz on the public side??"]
telegram10min
logpath = /var/log/nginx/access.log
maxretry = 2
bantime = 600
findtime = 600
[nginx-login2-week]
enabled = true
telegram1week
maxretry = 7
bantime = 604800
findtime = 86400
I have also setup the telegram1week.conf and telegram10min.conf in the actions.d directory to inform me about this ban via telegram.
The iptables-multiport.conf should come standard with fail2ban
The filters I use located in filters.d are:
nginx-auth.conf:
- Spoiler: show
- # fail2ban filter configuration for nginx
[Definition]
failregex = ^ \[error\] \d+#\d+: \*\d+ user "\S+":? (password mismatch|was not found in ".*"), client: <HOST>, server: \S+, request: "\S+ \S+ HTTP/\d+\.\d+", host: "\S+"\s*$
^ \[error\] \d+#\d+: \*\d+ no user/password was provided for basic authentication, client: <HOST>, server: \S+, request: "\S+ \S+ HTTP/\d+\.\d+", host: "\S+"\s*$
^ \[error\] \d+#\d+: \*\d+ no user/password was provided for basic authentication, client: <HOST>, server: \S+, request: "\S+ \S+ HTTP/\d+\.\d+"$
ignoreregex =
nginx-login.conf:
- Spoiler: show
- [Definition]
failregex = ^<HOST> -.*$
ignoreregex =
As you can see I have set the rules very strickt so 2 errors will ban an IP for 10 minutes and another 5 (7 in total) will get the IP banned for a week.
Jos
