Hi.
My Domoticz is running on Raspberry Pi 3.
I have for internet access login name and password.
Now in the logfile I regular find :
Incoming connection from: 139.162.79.87 [ but also from other IP's].
How can I 'keep the system closed'? Is this dangerous?
KR
-Bart
how to get rit of intruders
BartSr
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
woody4165
Re: how to get rit of intruders
Do not open domoticz port to internet and install a VPN to access to it.
Or check the domoticz wiki, there should be some articles regarding security.
- jvdz
- Domoticz version: 4.107
I am using Nginx as reverse proxy with a SSL connection and use Fail2Ban to monitor the Nginx logs and ban any connection after 2 failed tries. This way you run pretty secure.
You could also use the buildin SSL option, but never use the clear-text connection over port 8080 over the internet.
Jos
Jos
- Egregius
- Domoticz version: v2024.7
Fail2ban is the best option, I use it on my web server and on Domoticz.
And as Jos said, use ssl.
lost
This kind of message is just a connection attempt, no login or even trying to do so.BartSr wrote: Saturday 28 October 2017 12:17 Incoming connection from: 139.162.79.87 [ but also from other IP's].
You can't stop, for instance, web site indexing robots from trying to figure-out is there is something to index!
To avoid bruteforcers, fail2ban is a good option combined with a firewall to auto-buld temp rules to ban them.
tontze
- Domoticz version: Beta Ch
Can you post your fail2ban config on domoticz part ? What you have in filter file etc ?Egregius wrote: Saturday 28 October 2017 17:42 Fail2ban is the best option, I use it on my web server and on Domoticz.
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- jvdz
This is the fail2ban (jail.local) config I use in combination with an nginx proxy setup:
You have to update in the red marked items to your purpose:
The iptables-multiport.conf should come standard with fail2ban
The filters I use located in filters.d are:
nginx-auth.conf:
Jos
- Spoiler: show
nginx-auth.conf:
- Spoiler: show
- Spoiler: show
Jos
