Unclear ZWave Log Entries
hamish
Post by hamish »
I'm a bit OCD when it comes to wanting information on whether something is working correctly. So the logs are important to me. And clear logs even more important.
The entries in the domoticz log (Running 3.8648) such as
2017-10-27 06:34:32.760 (RaZBerry) Usage (Gazebo Lights Power)
2017-10-27 06:34:32.764 (RaZBerry) Usage (Power Meter)
2017-10-27 06:34:39.526 (RaZBerry) General/kWh (WineFridge kWh Meter)
2017-10-27 06:34:45.993 (RaZBerry) Usage (Main Hall Usage B04/2)
2017-10-27 06:34:46.003 (RaZBerry) General/kWh (Main Hall - kWh Meter)
2017-10-27 06:34:47.768 (RaZBerry) Temp + Humidity (Back TempHum)
2017-10-27 06:34:48.765 (RaZBerry) Temp + Humidity (Back TempHum)
2017-10-27 06:34:49.944 (RaZBerry) Lux (Back Light Levels)
2017-10-27 06:34:50.420 (RaZBerry) UV (Back UV)
2017-10-27 06:34:58.695 (RaZBerry) Usage (Shed Master Power)
2017-10-27 06:34:58.705 (RaZBerry) General/kWh (Shed Master kWh Meter)
Are almost meaningless to me... Now I can surmise that it's telling me my RaZBerry sent me some messages. Amongst them a few temperatures from Aeotec Multi-6's, power reports from a switch etc. But what it's NOT telling me is what was sent..
Any chance we can have those logs extended just a tad to add in the value that was received? Maybe the nodded as well (Since hhat makes it possible to tie it in to the OZW logs). Or failing that, can someone give me a hint as to where in the monolith these logs are generated and I'll doit myself and submit it...
TIA
Users browsing this forum: winnie and 1 guest
